Hi all
I see Hornby do a 4 amp transformer that is a good upgrade for the Hornby Select DCC unit - alowing you to run more trains and accessories:
C7024 Hornby DCC 4 Amp Multi Purpose Transformer
I was wondering if there was a cheaper alternative available from Maplins etc that anyone had found?
Thanks,
Matt.
Is there an alternative to the Hornby 4 AMP Transformer?
Re: Is there an alternative to the Hornby 4 AMP Transformer?
I was considering something like this:
http://www.suntekstore.co.uk/Universal- ... 0V-4A.html
Any thoughts?
Any thoughts?
Or even this -
http://www.suntekstore.co.uk/15V-4A-Rep ... -Plug.html
as it is only £8 inc delivery..
Hi,
There sure is an alternative...I have been using a Toshiba laptop power supply for ages with my Elite, Specs are 15volts 5 amps ...The current doesn't matter, it is a good regulated supply, here are a few links on ebay.
http://cgi.ebay.com.au/for-Toshiba-Sate ... 3ca9b3eeda
http://cgi.ebay.com.au/15V-5A-TOSHIBA-L ... 439d206af8
Either of these will do the trick. The link you supplied was for using a laptop on a plane or in a car.
Michael.
Michael.
Digitrax Super Chief, DT402D, BDL168's, CML DTM30 & SIGm 20's. DS64's.
Or get something that's really up to the job;-
http://www.maplin.co.uk/module.aspx?moduleno=231
Mike
Mike
![Image](http://i168.photobucket.com/albums/u173/SilverSurfer1944/HawkersBridge-1.jpg)
Hawkers Bridge - A work in progress
__________________________________
'A Diesel engine is a machine - A Steam engine is a living being, almost human'
I'm been using a 'NEWSTAR' Model NSC-40 switching power supply. This accepts input AC 100-240v 50/60Hz. output is variable; at 15v its 4.5Amp. I've been using it with my Hornby DCC controller for 6mths with no problems. It was purchased in a local hardware store at a third of the price of Horby's 4Amp power supply.
