halls current sensor
Don't think so. Its just an OptoIsolator with a darlington output.
An optoisolator is simply a Light Emitting Diode pointed at an opto(sensitive) transistor- current thru LED makes the transistor ( in case a pair of) conduct. No current thru LED, no light, opencircuit output. Cost about 40 or 50 p except if its in a nice plastic hang-up box when they are £1.99 or so. Usually in an 6 or 8pin DIP package with some pins not connected .
Need a data sheet try
http://datasheets.name/datasheets/170713/4N33.html for a 4N33 device.
If you have some others without the darlington ( two transistor) output stage , just connect a 5p external transistor.
The differences between the various devices are the speed of operation and the isolation voltage etc - neither of which are critical in this application , so buy the cheapest you can find .
The bridge rectifier is just a simple 50 Volt bridge - again a 4 or 6 pin DIP is all that is required - 1Amp or maybe 1.5A capabilty if you double head or use coaches with lots of lights etc. Again the cheapest will do the job.
A suitable Hall Effect device COULD be used in this application , but in my experience is neither rugged or reliable enough for this sort of application , apart from costing more initially. This is NOT a Hall Effect device circuit diagram though!.
