Thanks, yes I am pleased with the lining of Prince, however one day i will try using my bowpen, but for now the transfer approach works well for me. I bought the transfers from gaugemaster, and then had to cut the various rads, and link with straight lining, the transfers I used for this were as linked below, however following this, i noted that you can by purpose made 009 scale lining for prince, although it is a little expensive....
http://www.gaugemaster.com/item_details ... n&strType=The trees are purchased from international models, I have made wire trees, where neccersary, such as for twisty Oaks, where I wanted more chariture, but for the bulk of trees I use internation models ones, as they are about the right height to sit well, and they are worth spending the money (not as expensive as some good ready made trees on the market)
http://www.internationalmodels.net/acat ... Hedge.htmlI also use various Silfor mats which are purchased from international models, there grasses, heathers are the best I have seen, and certainly work better than scatter, these are linked below
http://www.internationalmodels.net/acat ... or_53.htmlI have also just orders some rubber rocks from the US, I found them on Google, and they look amazing, and also will not get damaged in transit (I hope) I have traditionally used plastic a latex models from coal, but this will be a first, i will let you know how I get on with them when I get back from Malaysia. I have ordered shale, which i think will represent rough cuttings, through slate. see link below...
http://www.cripplebush.net/shale/shale-6-detail-3.htmhope I can get an effect simular to these, I will be cutting it down in size so the sheet should go along way hopefully
thanks for the great comments
Alex
