Fitting Kadees to Non Nem Stock
What's the difference between the 19 and 20 Kadees?. At some stage I'm going to fit them to my Bachmann L.T. Pannier Tank, and some engineering stock. I was going to use No: 19s but now I'm not so sure it's all getting a little bit confuseing.....Too many Kadees........
COLIN.
longer shank, so the coupling protrudes further [on the 20]Bushey Troughs wrote:What's the difference between the 19 and 20 Kadees?. At some stage I'm going to fit them to my Bachmann L.T. Pannier Tank, and some engineering stock. I was going to use No: 19s but now I'm not so sure it's all getting a little bit confuseing.....Too many Kadees........
Ive recently been introduced to the wonderfull world of Kadees', the spare springs will be needed as I have lost one off already, but dont bother with the fitting tool for them, its quite simple to pick them up with a scalpel blade between the coils and fit them reasonably easily this way. Also I started with nem type couplings but then moved onto #5's. I found it fiddly trying to hold them (& the gearbox) together and fit to the rolling stock so I have started to pre-assemble them. to hold them together I use the tip of the soldering iron and lightly melt the sides together,( just 2 light "dots" where the side loops are) works an absolute treat as I tried glueing a couple together but the glue "wicked" into the coupling and made it U/S,
HTH
Charlie
HTH
Charlie
OK now I am confused.
I have got my 19's and 20's and have just tried to fit one to the Hogwarts Express tender. This has a push in pull out type coupler which I thought was an NEM pocket, but the bit that pushes in bears no resemblance to the Kadee's.
Am I right in thinking that this isn't an NEM pocket, or am I doing something wrong?
Not its not a NEM socket - see the top illustration atRaider wrote:OK now I am confused.
http://uk.geocities.com/shipleymodelrail/kadee.html
to glue one in place
