how to make signs
how to make signs
1. Go to www.newrailwaymodellers.co.uk/resources.htm and then download the signs.
2. Print them off.
3. Cut the one you want out.
4. Use old railway track line cut it to length with pliers.
5. Make a hole in the board.
6. Then use PVA glue to stick the sign you cut out on to the rail (use the flat side of the rail
7. Then it should look like this.( The sign says stop)
2. Print them off.
some of my things for sale http://www.freewebs.com/model-railway-h ... orsale.htm
put it in here so do not have to make knew thread
Would a rail be too thick... i.e. to scale would it not be like every sign being held up with a 8 inch wide girder!
If I were you (and it's a lot easier) I'd use the cheap wooden BBQ Kebab skewers, as you can cut them with scissors, spray them white (or grey), and bob's your uncle.
MY LAYOUT!
http://www.youtube.com/watch?v=E7BqAD92Ptc
