Fitting Kadee Couplers to Bachman Mark 1 Coaches
hi
I have today fitted some kadee couplings to bachman mark 1 coaches
although they have the NEM pocket the height is wrong and it needs a little alteration to get right
this is how i did it, based on Electric Nose method
there is only one photo of the end result on that page so i have detailed the process as if it had been there for me it would have been a help to see before attempting, as it was i just went for it!
remove bogie being careful not to loose spring that hooks into nem pocket collar thingy
i cut the top [or bottom, edit! see below] off the nem pocket and retained this to use instead of plasticard as mentioned on electricnose
which was glued in place carefully with the glue shown [mek pak no good ] using cocktail stick to apply and press firmly in place
i useed a kadee 20 to check heights
Mr proprietry rubberised blue adhesive was used to make a platform to drill through the middle of the altered nem
a track pin cut to size
was then glued in the hole holding the no.19 kadee in place
re-attached bogies and
viola!
all done
i used the no.19s as i have enough of them to do all my mark 1s with them for now
it just meant not pushing them right into the pocket so as to get the right length
i would suggest if you are going to buy couplings for this job get the 20s as its just more straight forard pushing them into a clipped in position rather than the 3/4 way as with the 19s
hope that helps anyone thinking of doing this, not too trickey a job, just a bit time consuming, i got 2 coaches done this evening, 3 to do
michael
viola!
all done
michael
Michael. I agree with Ironduke & Geezer , well done.
I did mine differently & did not use the existing coupler unit that allows for the coupler to extend as you did. I anchored mine direct to the bogie & I have no problems with buffer or diaphram locking but then I use 36" minimum radius.
But your method will be used in other coaches that I have to do.
thanks for the good pics.
regards
Ron Solly
Ron Solly
If you have a broken NEM Kadee (ie one that has lost its spring - I can never get a new one in place) then a simpler method is to cut the knuckle off the shank of the broken one and cut the NEM mount prongs off one that is okay. Then simply glue the pair together to make a stepped shank coupling.
With regard to N gauge Kadees are actually Microtrains couplings (a different company). The Microtrains 1129 / 1130 couplings apparently drop into the farish/dapol etc rapido coupling mount.
- Ironduke
you could use the prongs off the removed Bachmann TL coupler for that. I find the plastic doesn't take to glue very well, though.Mike Parkes wrote:If you have a broken NEM Kadee (ie one that has lost its spring - I can never get a new one in place) then a simpler method is to cut the knuckle off the shank of the broken one and cut the NEM mount prongs off one that is okay. Then simply glue the pair together to make a stepped shank coupling.
hi martin
there's a thread here that should answer some of your questions, beyond that i'm not too sure myself, i think no.5s are a standard choice for most uk stock that doesn't have nem pockets, also 30s/40s i think
i got mine from ebay, plenty of people on there selling them
can msn you a specific link if you want?
michael
michael
