Reusable, modular layout base in N-gauge
Re: Reusable, modular layout base in N-gauge
Next to weather the scene to take the shiny model look away. First some dilute black on a damp paper towel dragged along the dirt road
Then the same over the yard to where the building vehicle door will be
Placing the building confirms the road marks are about right
Here is a longer shot showing more of the scene. So far, so good
Next to finish the bushes, with a few over the track by the buffer. Not quite the standard I have seen on some OO models, but ok for now. The scatter within the track rails certainly makes a different look.
Another long view of the scene. This infill seems to match the adjoining section, so success
And for reference, here are two shots of the infill panel separated from the model.
alan_r, where did you get your textured plastic sheet from? It looks to be what I'm after for my layout.alan_r wrote:To give an edge to the front of the back section, I decided to go for a brick retaining wall. I bought some textured brick plastic sheet and spray painted in red. Again it was high gloss and ended up a pillar box red, so I didn't take a picture. Painting over with neat black acrylic and wiping off in up/down strokes however gave a very good effect, so I was quite pleased. The brick texture works, with the black filling the mortar gaps neatly.
Btw, I love the concept for your layout, multiple integrated modules, brilliant! It is something I have long dreamed of.
Keep the modules coming!
Anthony
- PinkNosedPenguin
Your scenic work is looking great - its all coming together a bit like you had a plan . I know how small everything is in N gauge as I have recently finished my N gauge layout - but the advantage is the sense of space which is so much more like the real world - "less is often more" .
Last edited by PinkNosedPenguin on Sat Dec 16, 2017 8:46 am, edited 1 time in total.
Looks fantastic, i know its a bit cliched but I've only just realised this is N!! Great work
Thanks for all of the comments - it is reassuring to know I've done a good job in other people's eyes. It does help knowing how to use the camera, though I still don't know why the pictures are uploading so small compared to previous uploads?
The camera does hide some of the imperfections though. The previous modules were made on 50mm polystyrene sheets which were quite rigid, but this drop-in module is only 15mm thick at the flat part. It has warped a few times during the various construction stages and I've had to keep adjusting it to fit. The grassy bank down to the lower level was supposed to have the join hidden by matchstick kerbs, being carved down to a cardboard edge, but the card wrinkles and the glue seems to shrink and bend the sheets. A bigger kerb or small wall may be required.
As with the basic engineering principle of beam theory, the stiffness is in the depth not the material (as in an I-beam)
So the big learning from this is not to make future modules out of anything thinner than 50mm
Anthony - the brick sheets are by 'Expo drills and tools'. They are listed as being 365x260mm, but they have a flat border leaving 345x240mm of usable area. However this should make a lot of walls (mine here are 22mm tall) and also will make many buildings I'd have thought. They initially seem pricey, but they come in packs of two and in N-gauge should go a long way. I got mine from Hattons:
http://www.hattons.co.uk/stocklist/1000 ... dlist.aspx
There seem to be 3 styles available though the website pictures might be wrong - the one in the model is 'English bond' (582-02) which is like our old solid wall pattern. I subsequently bought 'plain bond' (582-01) which is modern stretcher bond as you would see on modern buildings and single skin walls.
Just remember when weathering to use vertical strokes in the direction of falling rain! Initially I wiped the black off along the wall length horizontally and they looked ridiculous!
I just have to finish the narrow section between the back scene and the station and then I'll post some [almost] finished pictures with some trains on.
I've now moved on to the narrow infill piece between the back module and the station. The extra loop will be a running line, so it was necessary to cut an opening into the backscene board to allow the trains to pass through. Matchsticks form a kerb that is intended to hide the join between the back module and this infill
Then the interface between the two boards joined with a cutoff end of half a length of setrack. This join should be hidden by the concrete path of the station board
Then to fit a length of flextrack between the two ends
The back module had a yard built up from cardboard. For this one I decided to try using filler between matchsticks. This view shows the pre-smoothed initial fill. Cardboard is used to make a path to the steps of the back module
Once smoothed, the filler was painted, this time in the darker grey to see how this looks. The white line along the rail is where I trimmed the over fill. This was repainted later. Track also ballasted
Then scatter over the rough ground behind the station platforms, mostly brown but with a bit of green to represent weeds growing in the rough soil
Finally, some views with trains!
I've placed my self-modified tomytec crane with cable and suspended load, which I think looks superb in the flesh Unfortunately with the location so far back on the layout and the lighting position, the boom is casting a shadow on the backboard! D'oh! Something to remember when designing a scene in future Here you can see the path crossing the track to the steps. I'm pleased with the steps as a point of interest in the view. Also confirmation that a lorry will fit under the roller shutter door of the building at the back A careful selection of camera angle hides the boom shadow on the backboard! The painted brick sheet also looks good in this view, so I shall be making more of these walls A long view of the scene, showing more of the station platforms And a high level shot, this time with the mobile crane removed
The green overgrown siding contrasts well with my yellow breakdown crane, showing it off nicely
The breakdown crane siding in context with the new layout section
View of the new station area, siding module and the integration with the original bridge/tunnel approach module. I think this looks far more interesting than the previous road and double track, even if it did have an auto-signal. This gives things to look at when no trans are passing, and I can also enjoy just looking at static trains in the sidings
Here is a view of the current configuration, with the new station and sidings at the far end
So, what is left to finish? Whilst the grey shed nicely hides the opening in the backboard that allows trains to pass through from the siding behind the station, I definitely need something to hide the double track of the station in front. I'm thinking a pedestrian bridge to hide the high opening, with a full width canopy to hide the hole - not really realistic, but probably the easiest and most effective.
Cheers, Alan
I also have the scenic area in front of the station. Any suggestions as to what I could build here? I'm not just thinking of what would look good for a layout, but also what could I build to try out or practice something new? I'm thinking perhaps a block of flats or multi-storey car park at the left, maybe scratchbuilding houses out of the textured plastic brick sheets, but can anyone suggest anything else I might not have thought of that would be a good exercise for me to learn railway modelling? As you can see, it is a reasonably large square-ish area so there could be a number of possibilities
From this view of the whole layout, I think I've done enough countryside, so something industrial or more buildings are needed for me to try. Nothing too tall in the centre as the station would be obscured, but I'm sure someone can think up something original, or that I've not yet attempted
All suggestions welcome (for this final module, or perhaps as inspiration for the next version). Of course being modular, I can interchange between several options, so I can try more than one type rather than deciding on a single final choice. Thanks for looking and I look forward to any responses.Cheers, Alan
What about an outdoor lido/pool? Layout looks fab BTW
You have certainly got some scenery to be proud of. Shadows on the sky or across acres of hill side can be fixed! temporarily for photo sessions point a work light at them from a high up position, as near as you can get to above the object. I have some signals that have to be very close to the backscene so for a more permanent fix I've arranged my fixed lighting to wash down the wall and remove the shadow. On one of the Peco give away DVDs in the Railway Modeller, you can see Craig Tilley their photographer doing a timed exposure and walking around with a hand held light "painting out" any unwanted shadows. One of the photos in my layout thread has a nasty shadow of the viaduct arches on the wall behind because I didn't put my photo lights up high enough, under its normal lighting it doesn't happen the overhead light is directly above the track.
- PinkNosedPenguin
Looking very good . To take full advantage of your modular approach why not make two alternative contrasting scenes? One urban (e.g. flats, carpark, industrial units or abandoned canal wharf) and the other rural (e.g. open fields, country pub, farm or canal with lock). To make it more challenging, they could represent the same scene before and after 'development' . . . ?
...now there is an interesting idea! A time-lapse of development from old to new.
A good opportunity to build a construction site. I've seen these at exhibitions as they show off building frames, cement mixers, cranes, diggers etc and create real interest, and I'm sure it appeals to the sense of construction/engineering in all of us.
Starting with overgrown/derelict lines and buildings, leading to a construction site, then a pristine modern image scene. Brilliant - should keep me going for a while
Thanks - any other suggestions, or do we have a winner already?!
