![Image](http://image.ibb.co/g7thHw/IMG_20170316_210726043_zps2klfmjh2.jpg)
It started off life as a Bachmann 3F. The tender had its panel lines remove and solid flares added as opposed to coal rails, the footplate was extended 5mm or so, the dome was prised off and moved along a bit, the middle footsteps were added, the firebox was shortened and the cab was scratchbuilt. The only thing that irks me slightly is that the boiler is a couple of mm too large a diameter, but not really a lot I could do about that. Then everything was painted and lined out to within an inch of its life using crafty computer paper.
I also wanted to see how I got on with signals. The aim was to have them working such that I could switch them by hand of God using the balance levers only. I succeeded, just:
![Image](http://image.ibb.co/bYtMAG/IMG_20170205_182001739_zpsb43k6x60.jpg)
Although getting the brass wire just right for the right movement was I think the very limit of my modelling patience! I used MSE components and a scratchbuilt brass wire ladder that came out pretty well for a first attempt.
![Image](http://image.ibb.co/cHeHjb/IMG_20170519_103506051_zpsldh0vpca.jpg)
Elsewhere the signal box I made some time ago didn't make the cut. For some reason the clear plastic I used didn't react well with the glue long term and warped quite badly.Happily because I cut it out with the silhouette, I still had the drawings on my computer so banged out another one, and this is now almost finished, with an interior, from ratio I think, or maybe Wills...
![Image](http://image.ibb.co/egR54b/IMG_20170519_103544304_zpsczr4wl4i.jpg)
I'm still not rushing the station building, just doing odd bits as and when, still loads of bits to do, but a few chimneys have appeared among other things:
![Image](http://image.ibb.co/gXOUVG/IMG_20170519_104547056_zpssin1dfhj_1.jpg)
Now electrics isn't really my thing - I'm actually looking forward to ballasting as it will mrk the end of electronics work!
![Surprised :o](./images/smilies/icon_surprised.gif)
![Image](http://image.ibb.co/e1aOPb/IMG_20170410_121650351_zpsdw1vgs1f.jpg)
Ah well!
I was hoping to have some platforms by now, as once those are done I can really get cracking planting a lot of things I've already built onto the layout. However it seems to be the one thing I really can't do very well! I've wasted several weeks messing around with cardboard and plastic and thrown it all away, going for MDF now and hoping for better luck!
