Frankland update No. 10
Hello and welcome to update number ten.
Since my last post I've been working on basic landscaping along the front of the layout. A change to my original plan has been to make room for a stretch of embankment between the viaduct and the station. The embankment is built up with foam-board and topped with plaster.
At the opposite end of the layout the railway runs through a cutting and into a tunnel.
The empty space on the left will mirror the right-hand side of this picture - but will be removable for easy access and photo-opportunities
Retaining walls will be concrete, with cabling alongside.
As you can see, I've continued ballasting and the front of the layout is now done.
It's lightly weathered for now - and later I'll come back to detailing and more weathering.
Looking at old colour pictures of track around Clapham / Wimbledon I noticed that point-work could be quite oily at the business end of the points, covering sleepers and ballast too - so I used Railmatch 'Oily Steel'. It's also a good way of disguising the drop in sleeper height at this part of Peco points. I'll add a couple more washes some time.
I made a rough mock-up of the tube station that is at the top of the hill.
And a mock-up based on Wimbledon Station.
My original plan was to model my second station at the back of the layout on Wimbledon, which has a main entrance and a secondary side entrance.
But having made and positioned the main building - it just wasn't working for me visually in the space I have. So have decided to compromise with just the side entrance, imagining the main entrance is further along the road and 'off-scene'.
The side entrance to Wimbledon was the same architectural style as the front, just narrower. I haven't mocked this up fully, just a template for size and positioning which you can see in the next couple of pictures.
Moving down from this station we'll have a set of three mock-tudor semi-detached houses.
These will represent the speculative building of the period and will probably be the first area I work up into something more detailed. To me they'll give a good sense of time and place. The houses and gardens will be on a lift-out section for ease of working.
Finally, here's an overview of the left half of the layout so you can see how this area sits together. The top of the hill lifts off for access to the tracks.
The tonal range of colours you see here is roughly what I'll aim for with finished scenics.
Oh, the plywood station platforms I'd made previously have gone. They started warping - so I'm going to make platforms either from Plasticard, or foam-board and Plasticard.
And that's everything up-to-date.
Comments and suggestions welcome.
Mark
