Steam Trains to Sovereign Street on a 1914/1919 theme
Re: Steam Trains to Sovereign Street on a 1914/1919 theme
Post by Bufferstop »
This must be some kind of record, the Planet Industrials has been on the layout for over a week and it still hasn't had the top off. No need it's heavy enough for the job and the gearing is perfect for the speeds it needs.
glencairn
Post by glencairn »
Bufferstop wrote: Mon Jul 08, 2024 10:40 pm This must be some kind of record, the Planet Industrials has been on the layout for over a week and it still hasn't had the top off. No need it's heavy enough for the job and the gearing is perfect for the speeds it needs.
My Planet locomotive is a little gem and runs so pleasantly. Well worth the money.
In my case only truly necessary to have the body off to install the decoder. And the operation is all as it should be, two easily identified and accessible screws, body lifts off, replacement equally straightforward: while the body was off I took the oppportunity to inspect the neat and tidy mechanism construction.
Altogether as it should be in all respects, if this outfit produces anything further in OO I will be very interested. I have suggested that they might consider the North London Railway Park class 75 0-6-0T: a company loco that looks like an industrial loco, and from a railway with no RTR offerings to date. As a bonus it was latterly also used on the Cromford and High Peak operation.
https://en.wikipedia.org/wiki/NLR_Class_75
glencairn
Post by glencairn »
Methinks the thread has been hijacked!!!
Back on thread (hopefully)
1914 - 1919 A train of gunpowder vans heading south.
Port of Bristol authority boxvan acting as a 'barrier wagon'.
Experimenting with cotton wool steam, haven't tried that for ages. I'm waiting for someone to complain that their water mist smoke unit makes the scenery soggy!
aleopardstail
Post by aleopardstail »
Bufferstop wrote: Thu Jul 18, 2024 10:57 pm Experimenting with cotton wool steam, haven't tried that for ages. I'm waiting for someone to complain that their water mist smoke unit makes the scenery soggy!
do wonder if you run a few of them gizmos, firstly you will spend most of your running session trying to keep up with refilling them as the amount of water they hold is ridiculously small. secondly unless you have a set up so turning them off as they go into tunnels and back on as they come out works I think the potential to cause issues with damp, while small, is not zero
combined with they produce a few wisps and not a heavy smoke effect anyway I do wonder what the point is, beyond Hornby trying to tick a box currently no one else does and I wonder how long before this is something they stop adding
I seriously wonder how long these units will keep working. I was impressed by the flame and smoke effects produced by a dummy log burner that uses this mechanism under the name of "Optymist" two units over a period of four years failed to continue to work much after three months of use, even replacing all of the active components in them could get them going again. I'll hold my judgement!
Bufferstop wrote: Fri Jul 19, 2024 12:24 pm I seriously wonder how long these units will keep working. I was impressed by the flame and smoke effects produced by a dummy log burner that uses this mechanism under the name of "Optymist" two units over a period of four years failed to continue to work much after three months of use, even replacing all of the active components in them could get them going again. I'll hold my judgement!
I know when I first saw the effect on one of my nephews toys (Thomas I think it was), it did seem to last, so the theory of the idea that it can be made to last a long time is there and it did take a while before the "Smoke" ran out of water.... But toys have a lot more room than models have, and I don't know if the heating elements will be to the same quality as they were in the kids toys due to needing them to fit in a small space? It was around 20 years ago when I came across this kids toy as I had never seen one work from water before. Had the smoke oil type on toys in the past when I was little, but not water to make steam like these toys did!
glencairn
Post by glencairn »
New carriages from Rails/Hattons. Two in Lancashire & Yorkshire Railway livery and one in Great Central Railway livery
Fairbairn Lawson's Metal Workers have changed production to small arms manufacturing. Two wagons loaded with boxes of small arms.
Lancastrian
Post by Lancastrian »
Good to see the line is active again. :D
glencairn
Post by glencairn »
Lancastrian wrote: Wed Feb 05, 2025 6:56 am Good to see the line is active again. :D
Thank you, Lancastrian.
Yes, it has been nigh on four months since a train has run. Got to get back into running trains, a war to be won. :lol:
glencairn
Post by glencairn »
Some changes are being made. Clarence Dock has gone. It is now Leeds Sovereign Street Station and Yard.
The station now has two platforms (instead of one)
I still have room for a small dock area.
A lot to do and is slow going, but the layout is operationally better than before.
Nice! .....
glencairn
Post by glencairn »
Mountain wrote: Sun Mar 30, 2025 12:50 pmNice! .....
Thank you, Mountain.
Somethings haven't changed.
Jimmy Marston is still changing the wheel. Five years he has been doing that. Max the guard dog is wandering over to see what is going on?
Charlie Marston is still negotiating a sale for possible restoration of a locomotive.
A scene on the layout.
Phred
Post by Phred »
I well remember struggling and sweating for ages trying to undo some wheel nuts until someone pointed out that I had to turn them clockwise. I had never heard of reverse thread (or left-hand) nuts. :x
