More tinkering going on in the yard. A new member of the loco roster has arrived. Well not exactly new in fact very secondhand from the famous online auction site. Sold as faulty with poor running, no lights, detached bogie sideframes and missing horns. Another class 60 this time in Load Haul livery. Seemed worth a punt.
The poor running was easily fixed as one of the track feed connections to a bogie had become detached. Bit of disassembly and a dab with the soldering iron sorted that and I relocated the loose bogie sideframe at the same time.
Cramdin is all EWS and Freightliner so the beast needs rebadging. 60007 seems to have a real bodged rebadging initially with a big EWS 3 beasties vinyl sticker on one side and a small one, that didn't even cover the Load Haul branding, on the other. Had to be done!
Since DBS took over the EWS brand you can no longer get transfers for the beasties vinyls from Fox. What a pain! So I've been experimenting with producing my own with paper obtained via the interweb. One benefit that comes out of it is that I can produce the tatty mess that is the small sticker on top of the scraped and gashed Load Haul badging. More use of the interweb found me an ideal straight on picture of it.
After rebadging the beast has had a sound decoder fitted with a speaker underneath the exhaust silencer facing down. I built a custom ported enclosure for an oval speaker. Doesn't sound too bad.
Searching the interweb for replacements for the missing horns proved unfruitful. Nothing for it but to make some. Decided to dust off the trusty but very elderly Unimat and turn something up. Didn't have any brass rod of a suitable size but a bit of old wire coat hanger is close enough.
Can't really call it a turning job as I don't have all the necessary tools but application of various files produced these.
Bit crude but might do the job. Solder on a bit of fine brass wire to each...
Drill a couple of holes and bung em in with some super glue. Not an exact match for the Hornby part but with a dab of paint maybe...
By the time some cack has been thrown at them it'll take a good eye to spot. Especially if I don't park both 60s side by side.
Onwards. Better do some proper maintenance on the layout at some point prior to the next trip to Folkstone I suppose.
