Point Motor Wiring layout
Re: Point Motor Wiring layout
I looked back at the start of this thread and E2E's comment that he failed at the first hurdle because your method started on the un ballasted board. Assuming the slot was big enough and reasonably aligned it should be possible to drill the two 1mm holes through the ballast then proceed as you explained.
