Hawick via Grantham, Inverness and SIAM (00 gauge DC)
Ex-Pat
Re: The Shed-ends & window frames
Post by Ex-Pat »
Thanks Daniel (and not a tree to be seen!)
Work the switched to the shed ends – as can be seen the Wills sheet was not large enough to cover the end in one go.
So it was necessary to use another sheet once the first one had set.
Seen from the other side the join-line can be seen but it should be relatively easily disguisable.
Cutting out the door entries was much easier when using a piercing saw (it was too awkward to use this when cutting out the window spaces).
The card “frames” were added to the rear of the windows  and trimmed for a good fit of the windows.
T.B.C.
Daniel
Re: Hawick via Grantham, Inverness and SIAM (00 gauge DC)
Post by Daniel »
I think even only weathering will make the joint of the Wills pannels invisible to the mind but I'm sure you will find your way.
Good work, as usual.
Daniel
My new Flickr:
https://www.flickr.com/photos/158027525@N08/
My old Flickr:
https://www.flickr.com/photos/daniel_1_32_scale/page223
Being right is one thing, but being true is quite another.
Ex-Pat
Post by Ex-Pat »
Thanks Daniel.
The desired depth of window recess has been achieved and the next step was to
use De Luxe Materials Perfect Plastic Putty to fill in any gaps.  I found this material far more convenient to work with than Milliput filler as it is already mixed and easy to apply.
These are the recesses having been roughly filled with the PPP
and here is the final result after cleaning up.  The PPP has also been used to fill any gaps between the quoins and walls, and also the joints between the wall sections.
Work switched back to the shed ends again - in the background is a photo of the curved bricks forming the arch over the shed doorway, and in the foreground the arrow indicates the start of my scraping away the stonework in order to accommodate the curved bricks. (The sandstone colour is merely a trick of the night light - it's still grey!) The photo also shows how the original roof profile was built onto around 1955.
T.B.C.
Eastern
Post by Eastern »
Looks like work is progressing well - think the wait to see the final build will be well worth it!
East Cheltwell
__________________________
Charles[/color]
manna
Post by manna »
G'Day Gents
Busy boy, looking good.
manna
Ex-Pat
Post by Ex-Pat »
Thanks Eastern & manna.
Now all 3 arches have undergone surgery, and pieces of curved Plastikard cut out to form the bricks.  I only had to get the top curve of the brick as accurate as possible because
after cementing the individual bricks in place
the overhang could easily be trimmed away
to leave a nice flush edge
so all 3 arches are now complete and ready for assembly to the side walls.
T.B.C.
Ex-Pat
Re: This way Honey!
Post by Ex-Pat »
The latest addition to the loco stud is a Hornby A2/3, and its transformation (no prizes for guessing its new name) is covered in my Workbench thread at:
https://www.newrailwaymodellers.co.uk/F ... 17#p693517
Work on the locoshed progresses and will be updated in the next few days.
Ex-Pat
Re: A distressing time is called for.
Post by Ex-Pat »
Back to the locoshed.
flying scotsman123 wrote:Random stonework is always difficult, the random sheets are never the same random as what you want! Anyway, I'm sure you'll make it look just right.
Fs123 you're quite right there – whilst the size of the stones was more like what I needed, their relief was too exaggerated and I had to file/sand them flatter – an act of sacrilege some might think.
The centre and right hand side have been distressed but as the left hand side will abut the water tower there is no need to file/sand down.
Likewise the right hand side will be covered by the sand drying house so it too can be left as it is
This is the finished “depth” stone
compared with the original “depth” stone
All 4 walls are now ready for next stage.
Ex-Pat
Post by Ex-Pat »
Square section pieces were cemented to the ends of the side walls with the dual aim of providing a greater surface area to which the end walls would be attached, and also as a means of anchoring the completed building to the baseboard (details to follow at a later stage).
The distinctive windows were glued in place
Quite pleased with the depth of the window recess.
The cut-out middles of the window frames had been saved and were then glued between the windows - the purpose will become clear later.
Sills have been cut out for the windows
T.B.C.
manna
Post by manna »
G'Day Gents
Steaming ahead ! And yes those windows are different. :D
manna
luckymucklebackit
Post by luckymucklebackit »
Great progress Ex Pat, and high quality modelling as usual. Looking forward to seeing the finished shed.
Ex-Pat
Post by Ex-Pat »
Thanks manna & Jim
The sills have now been attached
Dabs of glue are on the black pieces of card between the windows, and
glazing strips have been attached – keeping the windows themselves free of glue.
Now the fun begins as
the first 2 walls are cemented together
the ugly strip at the corner of the walls will thankfully be covered in due course by the quoins.
Ex-Pat
Post by Ex-Pat »
All 4 walls are now attached and
the corners are masked off for a final flattening of the stone to ensure that the quoins adhere OK.
The first site-test.
Failed!  The corner is too close to the track and a loco doesn’t clear it!  So the track will have to be skewed over to the left.
The PW gang lifted the offending track
and re-laid it, ensuring adequate clearance.  The green light was given to remove the loco, and ballast the track.
Ex-Pat
Post by Ex-Pat »
The structure itself, although not warping, did “flex” a little and I hoped that pieces of Plastikard in the corners (as per arrow) would stop the movement
But then decided to continue “business class” by soldering transverse brass tubes in place
the pile of wood is to help keep the tube in place whilst soldering
job done! And the structure is now very rigid
T.B.C.
Daniel
Post by Daniel »
It has a characterful presence already, Ex-Pat, even if still whithout roof.
Daniel
My new Flickr:
My old Flickr:
