Good luck with your new project. To be honest, the first layout was a success because it gave you some practice for the 'real thing'
Will you be going around the edge of the loft now to maximise the run?
If so, good call. I did that with my old loft layout. Means you can get away with nice long, thin boards that make modelling all the more manageable!
You can also get away with larger curves. Beleive me, it's worth the larger curves when you are using long wheel-base stock like an HST. Are youing to use flexi-track? I'd suggest you do if you hadn't decided to already because i) it will make the job a whole lot quicker ii) It will be a fair bit cheaper too. iii) Plus, you can profile your own curves on the main line
My New Attic Layout !
Hey there infrontcat.
Yes its going to go around the edge of the loft. I've built all the baseboards today, its gonna be about 15ft long by about 5ft.
I wasnt going to use flexi track, its something I have no experience with... It would probably be a good idea to have a go... But I have just bought some Hornby 3rd radius curves, so I'm going to see how they look.
It took me all day to build the boards, and then I ran out of timber when it came to making the legs !!! So I've knocked it on the head for the day. Back to it tomorrow ! I'm rather excited about it, I havent made a layout bigger than the standard 6x4 !!!
wow thats quite a change there! thanks I think I'll be doing something very similar in my bedroom, as my around the walls layout isnt quite working out. Looking forward to the pics!
Just another question: what were the radius of the curves on your 6'x4' 3rd and 2nd radius? or 2nd and 1st? I presume 3rd and 2nd though
Jermey
Jermey
