rumour has it he ripped up the floor boards and found a basementdr5euss wrote:Yeah, left![]()
Lofty, shouldn't you be in the loft, or have you got another bad bout of indecision![]()
![Confused :?](./images/smilies/icon_confused.gif)
![Very Happy :D](./images/smilies/icon_biggrin.gif)
the peco track is already in the prog. if you look in the list of track you can select is has the code numbers for each point, they are the same for code 100 and 75 so are written SL88/188 [188 being the code 75]Foden wrote:Hi guys. been using this new XTrkCad now for a day or two using Hornby track, but with my layout I intend on using the Peco Streamline 75 track... is there any update files for the Cad of these?
I have no intention of running Hornby track, to be frank I think it's rubbish
Any help much appreciated
Matt.
Ah, as I suspected then I must be doing it wrong... I'm typically about as computer litterate as a chimp.mumbles wrote:the peco track is already in the prog. if you look in the list of track you can select is has the code numbers for each point, they are the same for code 100 and 75 so are written SL88/188 [188 being the code 75]
hope that helps
michael
hmmm, wouldn't have thought soFoden wrote:Nope, it's playing silly buggers mate. I'll try re-installing it without adding the Hornby Track on, might have caused it to start playing up maybe?
