O.K. This is going to take some time.
The video in question is one of mine and yes I have my Kadees working almost perfectly.
To achieve that takes care and sensitivity.
First - The Problem.
Kadees work on a gentle use of magnets to open the trip. There are two Kadee magnets.
One is fixed between the sleepers where, when set correctly they are just above rail head height.
These tend to offer a higher magnet pull to the magnetic trip, which is probably best adjusted to
JUST touch the magnet when pulled open.
These magnets do pull on magnetic axles & wheel sets. This magnetic 'Creep' can result in a wagon
being pulled gently forward during the opening window and therefore not being dropped as wanted.
Two is a much larger magnet designed to be laid under the sleepers. The nightmare here is that the
actual magnetic force you're going to be wanting to use will vary depending on the actual track you
are going to be running on. Think about it : Code 100 track has a deeper rail section and heavier sleepers
than code 75 with thinner sleepers and to complicate more you could use code 75 rail on very thin
copper-clad sleepers. I've done all three !!
I find under board magnets exert a greater pull on magnetic wheels & axles with a larger 'Creep' factor.
Now let's get away from the track magnets for a while and look at Wagons & their Kadee couplers, well
in fact we will start with standard well set-up Bachmann couplers. IF you have a super free running wagon
and move to couple-up it is possible for the force required to lift the hooks is greater than the force needed
to make the wagon roll. Try an experiment yourself VERY slow movement. I do have very free stock that is used
on my long freights where 20 is a short train.
With Kadees I find it takes even more force to open the jaws than the afore mentioned situation.
So now let's look at axle brakes for individual wagons. I fit 'loose' hard sponge brakes, usually but not always
acting on the axles. The harder sponge tends to exert pressure without grabbing the moving axle. The aim is
to get a 'dead' non rolling wagon, but one where the wheels are rotating. Sometimes I use a brake on each axle
to reduce the chance of wheel locking, but get the required brake effect. Here are some examples :-
A small piece teased between the Bachmann mounting and axle.
A larger piece resting on the Dapol coupler mounting
On some Vans and in this case a Dapol kit built Lowmac a piece that rubs the tyre
These are easily removable should I wish to remove the Kadee coupler, replace with my Bachmann version and
run the wagon in one of my unbraked long freights.
Braked wagons have the magnetic creep eliminated so are a step towards perfect Kadee working. The brake helps on
coupling-up and when separating a train over the magnet by providing a stable stop.
Now much of the above needs to be achieved because of the inconsistency of wheel sets. Some are highly magnetic,
like Alan Gibson steel rimmed plastic wheel types, Most marginally magnetic like Bachmann, Hornby, Dapol. Some are
non-magnetic like Oxford Rail (Brass) and an unidentifiable number of Dapol sets. Here is a video (If I can find it) of
some magnetic wheel tests.
https://youtu.be/VreNTGz8HJs?si=8MVCgfvSlo62AAJw
Currently I'm running 2 different shunting puzzles with Kadees, One, mine has underboard magnets, the other is the Clubs,
that I made using between the tracks magnets. The choice for the club was to make the uncoupling locations easy for all
to see.
https://youtu.be/JU9U9-DquR0?si=3jPj9dVTSoyXKQ4d More videos on the HSII thread in Layouts under Construction
https://youtu.be/qnqmvTkUTus?si=uehd2MqOI_-18gsc A bit more on the Green Frog Brewery thread in Layouts under Construction
I will add the videos later as this will involve going back many years and the 400 ? videos I have on Youtube.
I shall also read back what I've written to see if I've messed up somewhare !!
