Coppenhall Goods (Late Crest) 00
Tom@Crewe
Re: Coppenhall Goods (Late Crest) 00
Post by Tom@Crewe »
OK How would the (1.) semaphore look similar to A. or B. or something else, should the bracket for the shunt signal be on the right as the head shunt is on the right?
Never enough time...........
manna
Post by manna »
G'Day Gents
'A' would be fine.
manna
Tom@Crewe
Post by Tom@Crewe »
About 18 months ago I joined a local club which didn't work out and so joined another!
Because of this when I had modelling time I spent it doing research, club evening's and homework for the clubs and so nothing got done on my layout and therefore decided not to rejoin for 2020, I have stayed as a friend of the club and will go to their open days etc.
Because of this over the last month things have progressed. Yard lighting installed (ladders still to fit after some more scenic get done)
I have experimented with some baseboard cover, where I want some grass scrub land I wanted just a bit of unevenness, I used toilet paper and PVA-water mix for fine mache spread it out and put a full sheet on top and gently tamped it down with the end of a brush. have to paint, apply scenic's and static grass.
Just wood.....
Toilet paper mache
Post by End2end »
Those night shots are stunning. :o
You must be very pleased. Looking forward to seeing more as the layout develops.
Montfort2
Post by Montfort2 »
End2end wrote:Those night shots are stunning. :o
Absolutely true !
glencairn
Post by glencairn »
Another amazing layout to follow, Well done.
RailwayRobbo
Post by RailwayRobbo »
Yep, I love the night shots to.
Very atmospheric.
Pete (RailwayRobbo)
BrightonMan
Post by BrightonMan »
Looking great. Looking forward to seeing how that rough ground turns out, great idea.
Tom@Crewe
Post by Tom@Crewe »
Just added Diesel Refueling point.
Track still to oil up and dirty.
glencairn
Post by glencairn »
Very impressive. Well done.
Lachute
Post by Lachute »
Image Image Image
Lachute
Post by Lachute »
I can't find this wonderful coaling stage on your layout. Where is it ? :oops: Or maybe it's on another layout ?
Tom@Crewe
Post by Tom@Crewe »
Its a more recent edition. as is the Horse landing (still work to do).
Tom@Crewe
Post by Tom@Crewe »
I can't believe its well over 12 months since I have done any building.
well back to it and installing some dummy point motors and scenic items.
Tom@Crewe
Post by Tom@Crewe »
Close to done just needs some touch up with paint
And my little tribute to Ten Shop End Wall Crewe Works (also still needs finishing off)
