Also I've been working on bogie coaches since Christmas. The bogies themselves are ratio LNWR, everything is is totally scratchbuilt from plain plasticard.
![Image](https://image.ibb.co/cNXMNQ/DSCF5456_zpshwkvjtbp.jpg)
It's not perfect, but for a first attempt I'm pretty pleased. There is a bit of warping but I'm hoping this will be solved with the next ones off the line as the sides to the first one were only stored in a book with a weight on top. I've got two more coaches that have almost finished being panted that are currently sat in a flower press, which I'm hoping should sort those issues out.
Here's the "cruel" close-up shot:
![Image](https://image.ibb.co/fEq82Q/DSCF5463_zpsvosxt3o0.jpg)
I'm pleased my camera manages to focus so well, but equally I wish it wouldn't make stuff up! The windows really look fine, honest! I am pleased it's managed to show up the thin gold lining in places, you can see it best on the lower beading edge of the waistline. This was done by first applying a gold undercoat then scraping back the top coat, aided by he fact that when cutting plastic you get the raised edges.
Finally a shot just to show the lights:
![Image](https://image.ibb.co/bNaxwk/DSCF5458_zpsudledtfr.jpg)
...Which my camera managed less successfully. But shows the general effect. The NSR was an early pioneer of electrical lighting, skipping gas going straight from oil to electric. However as it was an early system it was quite primitive and temperamental, which is why I wasn't too bothered about the odd bit of matt black paint getting on the lightbulb as I was touching in areas of light seepage, which gave the light a bit o variation from compartment to compartment. I think my family thought I had gone mad - modelling in pitch black save a small string of fairy lights in a coach! The lights are a short section of 12V rice lights, with one per compartment and a small notch cut at the top of each compartment wall. They are powered by two 3V coin cells on the floor of the compartments. The body and roof are glued together but the underframe is removable, to allow battery changing
The underframe I've just had to have an educated guess at. The drawings I have don't really cover underframes at all, so I found some instructions to making up brass underframes from someone's series of kits and based it on that, with the components I already had.
Things still to do on it:
- Add buffers (I have the correct design in a draw somewhere...)
- End detail - one side should have steps which I need to experiment on, and the other the com cord equipment, which should be fairly easily represented by some brass wire, leading down to...
- vacuum and other pipes - I have these, but need to work out couplings and then fit pipes around them so as not to obstruct coupling
- A very small on/off switch for the lights, mounted on the underframe. The wiring runs along the underframe so should just need a cut.
- Grab handles - the NSR pattern are reasonably unique so no etches available, need to try with brass wire and a jig our former of some sort.
- Transfers - these will wait a while as I need to get a bit further on other things to make best use of transfer paper.
- Some warping is present, but as mentioned, hopefully use of a flowerpress will solve this
- The inner doorframe has raised edges from cutting visable - solved on subsequent by using the reverse side for the inner frame and swapping the sides over
- Louvres above doors need more thought
- With the limited testing done so far, 2nd radius curves are manageable but a bit tight. I'd like to try and loosen them up a bit by filing the inside of the solebar at critical points
Hopefully updates will be a bit more frequent and thus smaller and easier to digest, but I suspect I won't get much "proper" time until Easter now as I've a lot on. Hopefully will be able to keep some things ticking over, currently engaged in my first major cut 'n' shut loco, turning a jinty into an NSR equivalent. Pictures soon if it works. I've gone on the basis that if I can do this, I can probably do any other loco as each time I measure bits, less and less of the loco body stays original!
