surprising the 47 project isn't on here baught as a slightly upgraded hornby 47 the plan was to convert to dcc with sound and lights ( all required items baught and research done work has now begun
the aim was to keep it as standard as possible whilst using for a testbed to teach myself the required electronics as it goes it is a pretty simple task ( all bar trying to get my head round ohms law for resistors ) correct resistors , LEDs , wiring and heat shrink in place work started on building up the individual LEDs
once built up it was a case of mounting ( using as much of hornbys originality as possible ) the original lights position was taken by the LED then the LED was built in position and heat shrank into position
only real alteration required was to cut into the boxes at the rear of and below the drivers / second mans seats as the chassis butts up to it there so the wire needed to be recessed
also a small blind was fabricated from thick plasticard to stop light bleed from the lightbox LED to the windscreen
i will also use a difrent method with the red LEDS on the next build as they protrude and are a little large will be altered by paint (as is i painted over with red paint to knock down the brightness a little
