A new loft layout
Coal mine is going up as soon as I get round to going to Antics and getting the H gob and I beams
Dave I have soooooooo much space that eventually I hope to have a few circuits going on a couple of levels
Working on the control panel for the engine sidings at the moment will post pics when the stuff arrives from rapid electronics
Hows my driving - Phone me personally if you dare
First control panel for the engine sidings ready to be wired into points motors
I am using bi colour LEDs (Red / Green) and push to make switches to save on using the 5 quid ripoffs from hornby
The switches at the bottom are to make each siding track live or isolated
Thanks Rob
The Symbols are indeed from xtrackcad simply zoomed and placed in rows then printed
The wiring for the points motors will be through a CDU when I get a decent PCB schematic
Point motors are hornby and the switches for the leds are pl 13 from peco
The wiring I will use will be Cat 5 cable as it carries 8 core which is ideal as i need 7 core for each point
Bi colour leds are ideal as they will show green for a point set and red for a point set against
I will also be wiring signals up to the control panal to automatically set signals appropriate to a points setting
The possibilites are boundless
the schematic below shows the wiring of the pl13 to the leds
- Ironduke
Fairly straight forward but I think you'll need a resistor (1) in series with the leds
Are you going to make your own PCB for the CDU or just use the circuit? CDU kits are fairly cheap (over here at least) I just bought one. It was cheaper than it would have been to buy all the bits individually, including vero (strip) board. But I don't know if you have electronics hobby shops over there?
There's a few diagrams on this site:
http://www.simplytrains.com/pages/hints ... du/cdu.htm
Might help
Pete
Might help
Pete
- Ironduke
ha, I shoulda thought of them.. I've got an article in there (making little people).
There's a book called model railway electronics which, I believe, has a project for a CDU among other things.
I also found this: http://home.cogeco.ca/~rpaisley4/CDPSU.html
but I didn't think much of his circuits :^) I mean nice drawings and everthing but I thought they were a little bit complicated
Progress is slow at the moment due to having just fitted a new kitchen but the first long tunnel is in place
just hope the coal miners dont sink the shaft through the middle of it
A more detailed update will follow when my wife is eventually happy with the way the garden looks
- kristopher
Its the metcalfe kit and has lighting installed I also have made the brewery which is also lit and is my next job to finish as it is situated between my coach sidings and the wagon sidings
