Frankland update No. 7
Hello and welcome to update number seven.
Since my last post I've completed around 70% of wiring, with just the junction at the back of the layout remaining to be done. Similarly, the control panel just requires wiring for the last junction.
At some point I'll build a scenic section to drop over the control panel for when I just want to sit back and watch trains go round ... current thinking is that this section will contain a deco-style Lido. Something like this would be quite nice:
I've tinned and soldered wires and connections throughout (which has taken quite some time, but probably worth the effort). Points are now wired for polarity. Here's one of them:
I worked on the junctions as a whole rather than working on each point separately. This was because I found lifting and repositioning individual points was causing rail joiners to bend/become loose, plus I don't like having to keep wriggling track/points in and out of position more than necessary. Here's a junction dropping into place:
I needed to take a break from wiring for a while so over the last week have started making the foundations for the scenic areas. For inspiration and to get a sense of scale I made a purchase
Strictly speaking the coach is a little late for my period - but it has the right look and feel and I'm happy with that. I've also got the Southdown version on order
Last weekend I positioned the board which carries the hill up the centre of the layout and roughed out the route of the road. The board isn't fixed yet, I'll do that when the remaining junction is wired in. Anyway, here's an overview:
You'll see bits of card which represent various buildings placed along the roadside.
Whilst I plan to scratch build many of the structures on the layout, some I will construct from kits. I can't wait to get started on these 30s semi-detached houses from Kestrel.
And here's a view down the hill:
At the bottom of the hill there's a road junction where the road diverges to the left and straight-ahead and disappear under the viaduct:
These are not the buildings I will use - they're just to help set-the-scene.
Yesterday the final board at the bottom of the hill was put in place allowing the road to continue through under the viaduct to the far side of the layout:
Today I've worked on the top of the hill where the road turns and crosses over the railway at the back.
Again, buildings and blocks of wood are used to rough out the scale and position of structures.
I'm considering a couple more bridges here as scenic breaks for the roads (so the roads don't just 'drop off' the side of the layout or run into a blue backboard).
I've been reading recently about the LBSCR AC electrics - and depending on space - may use these bridges and a short length of viaduct to model a stretch of overhead track and a train (static, not powered). I think a future layout will have to accommodate AC EMUs as well as third rail
I've also been reading up on the history of railway developments in South London and it's got me quite intrigued: For example, Waterloo was originally planned as a through-station en-route to a terminus near London Bridge, and the LBSCR may have shared Waterloo with LSWR. Similarly, proposals were made for a terminus at Millbank (Westminster).
Millbank Penetentiary, proposed site for Westminster Terminus
This got me thinking about various 'what if' scenarios and I have started drawing up a timeline of railway construction in South London. Later I'll draw up an alternative timeline to see how routes, stations and junctions could have turned out differently had some of those earlier proposals come to fruition... and somewhere in there perhaps we'll find Frankland. It would be nice to have a sort of history
Saving the best for last: On Friday my Membership of the 2mm Association finally arrived - which means I can now order the Code 40 for my third rail.
So that brings us up-to-date with the latest work, news and thoughts from the wonderful world of Frankland
Mark
