Back to work.
May be you remember I had a 3Dprinted steel mold for forming the barrel tiles and was going to install it in a pliers...
Well, for many weeks I had totally lost trace of the mold but two days ago it came to say 'hello' smiling...
IMG_0029 (153) by
Daniel Osvaldo Caso, on Flickr
Using the steel rod registers for aligning the two mold parts while glueing worked perfectly...
IMG_0030 (161) by
IMG_0031 (160) by
IMG_0032 (158) by
IMG_0033 (155) by
IMG_0034 (149) by
Removing trhe regiusters once the epoxy was ready was also very easy...
IMG_0035 (152) by
IMG_0036 (148) by
Alignement went perfect...
So far the story is a success...
IMG_0038 (139) by
But what this photo let see is a lie:
It will work but not with a pliers construction. It will really need a lot more power because I am not able to get the work done by hand, as expected.
The formed tile in the photo was made with the previous method but to do it in just one step will requiere one of these which I bought a couple of years ago butr never used yet:
www.hbm-machines.com/nl/p/hbm-05-ton-tandheugelpers
And there is another thing: My plan was to file carefully a 0,5mm deep on both sides of the top surface of the female half so to keep the aluminium plate properly aligned until the pressing work do the forming... but my lone brain cell forgot. Anyway i must order now a new mold print because can't expect to recycle the one now epoxied to the pliers. (Mrs. Learning Curve is around here, again!)
