Hawick via Grantham, Inverness and SIAM (00 gauge DC)
Re: Ian Kirk coaches numbered at last.
Finally got round to this job and
became
I have put a fuller account of how to work with Methfix transfers in my Workbench thread at:
https://www.newrailwaymodellers.co.uk/F ... 00#p689298
became
Re: Hawick via Grantham, Inverness and SIAM (00 gauge DC)
Very nice done, Ex-Pat.
The atmosphere is really there.
Daniel
Daniel
My new Flickr:
https://www.flickr.com/photos/158027525@N08/
My old Flickr:
https://www.flickr.com/photos/daniel_1_32_scale/page223
Being right is one thing, but being true is quite another.
My old Flickr:
G'Day Gents
A red letter day, but, No ribbon cutting with speeches !! Your coal stage certainly looks the part, big thumbs up.
manna
manna
Thanks Daniel & Manna.
I’m now switching to the ashpits area at the loco shed itself.
Now, here’s a teaser on a different subject – this is a jig to hold these 1.75 inches long pieces in place whilst they have their edges painted (a couple fell after painting!) – but what are the pieces for?
To answer your 'Quiz'.
The inner sides of the Ash Pits?
Ex-Pat. I am sure you intend to 'blacken up' the area around and under the coaling stage once the Ash Pits are done.
Congratulations on the work done so far.
Thanks glencairn
Yes, I do intend to blacken up a bit (the flash effect has whitened it up a lot!).
However, sorry no, the pieces have nothing to do with the ash pits.
Re: Spot the difference and Rule 1!
Although my chosen time frame is circa 1953 I just have to run “The Waverley” express even though it didn’t start running as a named train until 1957 – so Rule 1 applies.
This
became this
In case anybody fancies having their own named train I have covered the detailed board/transfer application in my Workbench thread at
https://www.newrailwaymodellers.co.uk/F ... 98#p689698
and that should put you out of your misery glencairn!
This
became this
Hi, first time I've seen your layout and have to say after a fairly quick skim through the 20 pages your skills are impressive. Love the way you built the base boards. I feel mine's a bit of a cop out now but time will tell.
Excellent work on the scratch build too not to mention the turntable. It's not my era for modelling but certainly looks fantastic.
Ex-Pat wrote:Although my chosen time frame is circa 1953 I just have to run “The Waverley” express even though it didn’t start running as a named train until 1957 – so Rule 1 applies.
Sneaky! Ex-Pat setting a quiz and the answer is out of his timeframe.
Seriously. Looking good Ex-Pat. Are they removable?
Many years ago in the 'Railway Modeller' (I think), someone attached fine wire to the coaches and was able to slip the nameboards in and out. Minds't you it was a GWR layout and had different nameboards of trains heading to and from the west using the same coaches.
Thanks glencairn - only if the G-S HYPO fails! (It's never failed yet even though it's not a super glue and, in fact, Fox more or less dissuade its use by specifically pointing out that super glues can become brittle over time.) You could however always overlay with different transfers of the same size.glencairn wrote:
Thanks bootneckbob - I'm following yours with interest too (even though it's not my era either!). I used to play SIAM's 1955 Exeter simulation many years ago, and I went to Exeter several times in the 1980's and 1990's so I'm not totally out of touch with operations there.
- railwayjim
Just had an enjoyable read Ex-Pat, catching up on the advances since I was last on here.
I always said I can't wait to see it painted
I absolutely love it.
Cheers Jim.
Cheers Jim.
Thanks Jim - but I'd rather have MIllsend!
To bring things more up to date:
In the meantime I have been working further on the loco shed ashpits area, filling in some of the areas between the tracks, and then on the ashpits themselves.
Followed by a trial fitting
T.B.C.
The jury returned a split verdict, so the judge decreed that cereal packet cardboard should be used on the basis that the cork was both too thick and subject to degradation, and the closed cell foam was also too thick (even though perfectly sustainable).Ex-Pat wrote:And this is the first step towards achieving those results. (Whilst I will use closed cell foam (as shown) between adjacent tracks, the jury is still out as to whether I will use cork or closed cell foam for the individual tracks themselves).
T.B.C.
Blimey - it's cold upstairs - however:
T.B.C.
T.B.C.
Not finished yet – but getting there.
