Oh...NO...! Not another 1/32 diorama...!!!
Daniel
Re: Oh...NO...! Not another 1/32 diorama...!!!
Post by Daniel »
Today the building beside the factory will get it's door & windows.
They still need a bit of weathering and I want the three pane window to look different, as bought second hand somewhere to replace a four pane broken one...
ImageIMG_0013 (184) by Daniel Osvaldo Caso, on Flickr
I also wanted to see the wooden window test painted so...
ImageIMG_0007 (209) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0009 (209) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0011 (220) by Daniel Osvaldo Caso, on Flickr
Of course I have found an error: I should have made the stirene angle piece a bit broather for this size so each pane could see as standing. Next time I'll take care of that. Anyway I can live with the rest of the result.
My new Flickr:
https://www.flickr.com/photos/158027525@N08/
My old Flickr:
https://www.flickr.com/photos/daniel_1_32_scale/page223
Being right is one thing, but being true is quite another.
Daniel
Post by Daniel »
Early in the morning, walking through the always delicious darkness of my home to reach thge toilette, I noticed something in one of the lower shelves in the workroom that had long ago forgoten.
Here some images of what I saw...
ImageIMG_0030 (146) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0031 (146) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0032 (141) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0033 (139) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0035 (121) by Daniel Osvaldo Caso, on Flickr
It is a tiny 1/32 diorama I've made three dioramas ago. The front is 14cm, it is 18cm deep and 24cm tall. Not really a big thing. I have posted plenty about by then somewhere and, of course certainly to my Flickr. But because I never intended to give it any lights, todays surprise view under early morning light was really new to me too.
Now back to the current work
The little building with the fellow repairing the fram of his cycle has a big chance of emigrating but is still there...
ImageIMG_0013 (186) by Daniel Osvaldo Caso, on Flickr
... but meanwhile I make a bit of progress at learning how to make convincing curtains...
ImageIMG_0015 (167) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0014 (171) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0016 (172) by Daniel Osvaldo Caso, on Flickr
... and also in other areas work goes on...
ImageIMG_0017 (186) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0019 (174) by Daniel Osvaldo Caso, on Flickr
... here trying to build up the terrain for the big house recycling rests of foam from past dioramas...
ImageIMG_0020 (171) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0022 (168) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0026 (158) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0027 (161) by Daniel Osvaldo Caso, on Flickr
Also I noticed the muses are considering to give me more work on these zone...
ImageIMG_0028 (140) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0005 (232) by Daniel Osvaldo Caso, on Flickr
My new Flickr:
My old Flickr:
Nevadablue
Post by Nevadablue »
I really like seeing that old section of diorama and the new angle views of the current one Daniel. Delightful!
Daniel
Post by Daniel »
Nevadablue wrote:I really like seeing that old section of diorama and the new angle views of the current one Daniel. Delightful!
Thank you, Ken.
It was a surprise also to myself. I never even considerd giving that tiny diorama any lighting but the first lights of the day did just in the right moment and the right angle.
The diorama has been in that place for a couple of years and never toticed that light effect before.
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
Well, doesn't matter scale or gauge, we all know that laying track goes always different than prototypical...
ImageIMG_0126 (25) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0127 (23) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0128 (23) by Daniel Osvaldo Caso, on Flickr
While the glue dries the garden area of the house with the balcony started to be...
ImageIMG_0129 (22) by Daniel Osvaldo Caso, on Flickr
... but also needs to dry so...
ImageIMG_0130 (23) by Daniel Osvaldo Caso, on Flickr
Just the two first layers but it gives already a n idea...
ImageIMG_0131 (18) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0132 (16) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0133 (23) by Daniel Osvaldo Caso, on Flickr
I already did the rough vacuum to remove the lose grass but before doing the fine one I must... :evil: ... wait for the glue to dry...!!!
ImageIMG_0134 (19) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0135 (23) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0136 (25) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0137 (18) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0138 (25) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0139 (23) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0140 (20) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0142 (25) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0143 (26) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0146 (17) by Daniel Osvaldo Caso, on Flickr
Kitchen time!
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
ImageIMG_0044 (100) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0045 (109) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0046 (97) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0047 (105) by Daniel Osvaldo Caso, on Flickr
Don['t worry, the vacum must still do it's job but that will be tomorrow as the glue is really dry.
ImageIMG_0048 (95) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0049 (90) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0050 (92) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0052 (87) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0053 (96) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0054 (78) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0055 (85) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0056 (79) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0057 (75) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0058 (77) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0059 (80) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0060 (81) by Daniel Osvaldo Caso, on Flickr
Thew buildings are not glued in place because a lot of work must be done first.
ImageIMG_0062 (74) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0063 (73) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0064 (65) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0065 (71) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0066 (72) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0067 (69) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0061 (73) by Daniel Osvaldo Caso, on Flickr
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
ImageIMG_0070 (61) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0072 (48) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0073 (60) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0076 (59) by Daniel Osvaldo Caso, on Flickr
No vacuum yet but at least you can fly above the village.
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
ImageIMG_0031 (148) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0034 (133) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0035 (133) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0036 (136) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0037 (116) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0039 (119) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0040 (107) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0041 (96) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0042 (98) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0043 (101) by Daniel Osvaldo Caso, on Flickr
There will be some gras and enough stones at the right edge of the water but for some for me unknown reason Magoo is delaying that again and again...
ImageIMG_0044 (94) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0045 (110) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0046 (99) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0047 (106) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0048 (92) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0049 (91) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0052 (89) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0053 (98) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0054 (80) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0055 (88) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0056 (80) by Daniel Osvaldo Caso, on Flickr
My new Flickr:
My old Flickr:
Ex-Pat
Post by Ex-Pat »
Nice to see some track down, and the weir/waterfall is superb - I can almost hear the water flowing over it.
Daniel
Post by Daniel »
Ex-Pat wrote:Nice to see some track down, and the weir/waterfall is superb - I can almost hear the water flowing over it.
Thank you, Ex-Pat, for your comment.
Yes, I am also happy with the development of the diorama.( And surprissed too.)
Yes, some track is needed and that may be an aspect of next diorama: an abandoned small loco and rolling stock maintenance & repairs yard already being reclaimed by Nature... So still no running trains but plenty of derelict track & rolling stock in both narrow and standard gauges...
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
Long ago, I bought in a saddly already gone model trains shop nearby my home these two thin lead strip rolls
ImageIMG_0060 (83) by Daniel Osvaldo Caso, on Flickr
It is a selfadhersive strip...
ImageIMG_0061 (75) by Daniel Osvaldo Caso, on Flickr
I had by then no idea why I bought them but just did. (something I love to do, makes Magoo's fantasy jump and terrifies Mr. Wallet).
Today I thought may be it is the day when I could prove 'I was right' (...) because must...
ImageIMG_0062 (76) by Daniel Osvaldo Caso, on Flickr
The material seems simply ideal also if I not sure the French ever used lead for covering such roof joints. So dar I had the idea they were all zinc or even iron plate but not certain I ever seen ik done with lead...
Still, in the spirit of 'organic architecture' (a bit extended by need to the modelling area) seems it could have been. After all it doesn't sounds or looks too strange...
ImageIMG_0063 (75) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0063 (76) by Daniel Osvaldo Caso, on Flickr
I think I could live with such a tiny probably lie BUT: the bright surface of it is really destructive!
So I have two questions:
1)
Would it be technically pure nonsense to use lead?
... and
2)
Is there a good way to make the lead to oxidize without waitinmg a fdecade or two to get it happen?
I know lead won't get 'rusty' but somethging happens to it that after lonmg exposure becomes very matt and opaque.
Hmm... No, three questions:
3)
Would look better a stip of thin card painted as old zinc?
Daniel
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
In defense of the use of the lead strips I must say it can be done better than in previous post...
ImageIMG_0001 (270) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0002 (243) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0004 (230) by Daniel Osvaldo Caso, on Flickr
ImageIMG_0003 (225) by Daniel Osvaldo Caso, on Flickr
My new Flickr:
My old Flickr:
Daniel
Post by Daniel »
I have now discovered the last images show traces of the French blue powder I used used for the slates under the layer of black paint so a new airbrushying may be needed for the full roof or at least here and there. Extending that job to airbrushing a layer of an a bit greyish matt varnish on the lead could help...
My new Flickr:
My old Flickr:
Your work would be amazing to see at an exhibition. I would be looking at it for ages! I recently saw someones layout and I had seen his lovely scenes before on a narrow gauge forum. Seeing it for real and there is too much detail to take in but one gets a sense of perspective. We had to tear ourselves away because we had to get back before dark as we have ducks to put in to prevent the foxes getting there first, but I could have stood there for ages.
