SCARM - Simple Computer Aided Railway Modeller
Re: SCARM - Simple Computer Aided Railway Modeller
I have just completed my track plan based on Roco GeoLine track using SCARM. This program is simply great! It's easy to use as well! Highly recomended!
Carpe Diem!
Thank you Rosenblad ![Smile :)](./images/smilies/icon_smile.gif)
If you want to share your SCARM design, post about it in the forum or send it to me to
Here are the SCARM railway blog posts for November.
See also the recently posted Virtual HO-Scale railcars with military vehicles, which are also suitable for using in OO gauge layouts for those, who are modelling layouts with military scenery.
![Image](http://www.scarm.info/blog/wp-content/uploads/2015/12/SCARM_Virtual_Military_Model_Train-3D_1-500x275.jpg)
Mixy
![Image](http://www.scarm.info/mail.gif)
Mixy
Mixy, here it is!
![Image](http://i167.photobucket.com/albums/u138/rosenblad_photos/New%20layout_zpsj8hpse9i.png)
Not exactly complicated, but fun anyway!
Carpe Diem!
Cool plan
It is not needed to be complicated, just needed to be enough for fun with the running trains on it ![Wink ;)](./images/smilies/icon_wink.gif)
And here is the list with SCARM railway blog posts for December.
Don't miss the last post for 2015 which is representing the beautiful Badalona train station in N scale as virtual model in SCARM![Smile :)](./images/smilies/icon_smile.gif)
![Image](http://www.scarm.info/blog/wp-content/uploads/2016/01/Badalona_train_station_virtual_model_3D-500x241.jpg)
Mixy
Mixy
Here is the only post in SCARM Railway Modelling Blog for January:
Reset SCARM Settings to Defaults
Use the method, described above if you want to revert to default settings and/or if you have troubles when starting the program - resetting can be of help.
I am in process of finishing some new features in SCARM and the next version will be released soon![Smile :)](./images/smilies/icon_smile.gif)
Mixy
Mixy
Check the recently published post in the blog about Various Tanks & Water Towers in HO Scale and use these in your own HO or OO layouts.
![Image](http://www.scarm.info/blog/wp-content/uploads/2016/03/SCARM_fuel_tanks_and_water_towers_HO-scale_3D-500x275.jpg)
And the SCARM Railway Modelling Blog post for February is about possible Discrepancy Between Elements on the Layout and the Parts List - check it to see what are the most common causes for that.
Mixy
Mixy
The new version SCARM 0.9.32 is ready and published, coming with new Flip and Rotate features and many new and updated track libraries. Read more details here:
SCARM Model Railway Layout Software 0.9.32 Released
This version also fixes several annoying bugs that may appear in the older releases, so update is recommended![Smile :)](./images/smilies/icon_smile.gif)
Mixy
Mixy
It looks interesting, but I only saw mention of Windows when I looked at the system requirements. Will it run on a Mac?Mixy wrote:I want to introduce my freeware layout design program, called SCARM, which you can download and test from www.scarm.info.
- Roger (RJ)
Only under a windows emulator (or whatever they're called) such as Parallels.
I thought that might be the case, which would mean spending up to $100 to run a free program. I think I'll give it a miss.Roger (RJ) wrote:Only under a windows emulator (or whatever they're called) such as Parallels.
Well, SCARM is for Windows only, but there is an option for running it also on Mac platform without spending a cent. See about that here:
Running SCARM on Apple Mac
With the help of another free-for-personal-use software package and having SCARM already on your PC, it may run also on any mobile device, such as iPad or Android tablets:
Using SCARM on iPad and Android Tablets
![Image](http://www.scarm.info/blog/wp-content/uploads/2016/05/SCARM_on_7in_tablet_device.jpg)
Mixy
Mixy
Thanks for that. I'll check it out later.Mixy wrote:Well, SCARM is for Windows only, but there is an option for running it also on Mac platform without spending a cent. See about that here:
Holy Bovine, it actually works. Apart from the 3D view, same issues as on Linux I presume. Also space ("repeat last task") doesn't seem to work.Mixy wrote:Well, SCARM is for Windows only, but there is an option for running it also on Mac platform without spending a cent. See about that here:
However I'd like to point out that the above blog link says:
Note that the linked blog explains the installation using Homebrew, which is fine if you are technically minded and use Homebrew, but the Wine wiki says there are OS X packages available, which should be easier to install without resorting to the terminal. (For the record, suffering from a technical mind, I installed Wine via Macports, which is similar to Homebrew).read Installing Wine on Mac OS X [External link] by David Baumgold – detailed guide about installing WINE and using Windows applications on Mac with it.
If you have an unencumbered Windows installation media available, "VirtualBox" is a free emulation software which enables you to install Windows (or any other OS) on a virtual machine on your Mac. I use it under Linux mainly to run SCARM.Wolseley wrote:I thought that might be the case, which would mean spending up to $100 to run a free program. I think I'll give it a miss.Roger (RJ) wrote:Only under a windows emulator (or whatever they're called) such as Parallels.
