Point motor advice
aleopardstail
Re: Point motor advice
Post by aleopardstail »
rreckless wrote: Fri May 30, 2025 11:06 pm
aleopardstail wrote: Fri May 30, 2025 10:47 pm Never used python, just C/C++ here, something I found pretty useful was a class object to manage the thing, then a loop function you call with an elapsed time from the last time it was called - makes it reasonably simple to have a constant angular velocity or a constant time period to go between two positions. slow movement is wonderfully quiet too
I have an object to manage the PCA9685 and another for an individual servo, end up with an array to loop through.
likely have a video coming up on the actual software set up I use
I'll be watching that video!
now there is incentive about having to make it :)
rreckless
Post by rreckless »
What do you use as a rod for the point motors?
aleopardstail
rreckless wrote: Sun Jun 01, 2025 11:10 am What do you use as a rod for the point motors?
Servo pushrods I got from Amazon in a bag of about 50, they have the "Z" crank in one end pre-made, cut to length. I have a 3d printed mount (available free from https://www.thingiverse.com/aleopardstail/designs if you have a printer).
can also use 0.8mm piano wire - point is it needs to be both stiff and springy to work without staying bent
centenary
Post by centenary »
You can use piano wire for point motor throw wire. If you've a local modelshop they should have a supply as RC modellers use this for servo throws on model aircraft.
Dont use thick rod that can also be used in RC. This does not have the spring and will wear out the micro servos used to throw points as these generally use plastic gears.
