Thanks for showing Derek. I'm intrigued by your Countess, could you post more about it?
Tony
The Locomotive in question was 6024 King Edward I, the track had been reballasted slightly higher than normal, and as the safety valve bonnet is the highest point of the king, it collides with Bishop's Bridge, the quick actions of the crew to drop the fire saved the day,Mountain wrote: ↑Thu Apr 04, 2024 9:17 pm
Around a decade or two later one of the preserved King classes on a steam special should have been running on one of the main lines in the Reading area or between Reading and London Pad? and was diverted into a loop to allow another service to pass. Unknown to the traincrew and the signalman the loop didn't have sufficient height with an overbridge and it took the Kings safety valve clean off. I was working on the railway at the time, so we heard the goings on. Not sure which King it was. (King George V was off the rails by then needing work on her boiler).
One would have thought they would alter the height of the track just incase other locos and stock may hit it? I know Kings had some of the largest dimentions (Height and width at the cyliners if I recall) which gave them a double red when it came to route restrictions.roadie stu wrote: ↑Tue Sep 10, 2024 10:06 pmThe Locomotive in question was 6024 King Edward I, the track had been reballasted slightly higher than normal, and as the safety valve bonnet is the highest point of the king, it collides with Bishop's Bridge, the quick actions of the crew to drop the fire saved the day,Mountain wrote: ↑Thu Apr 04, 2024 9:17 pm
At the next overhaul the chimney, safety valves and cab roof were all lowered to prevent any chance of a repeat accident.
Stuart
