I didn't even think of that, It would flow so much better. Thanksluckymucklebackit wrote:Just run the two tracks in parallel, gives you a longer loop line.
Need help with a plan-OO gauge
Re: Need help with a plan-OO gauge
- Ironduke
Are you using Hornby set track? I see you have used a couple of flex tracks in there. I'm having a devil of a time to make it work in set track only.
- luckymucklebackit
Here is how I would do it, it also removes the clearance issue pointed out by Mountain, the crossover is optional
![Image](http://farm9.staticflickr.com/8329/8370363176_df27c9fdb8_n.jpg)
With two tracks in parallel you can run two trains at the same time. Just a thought.
Back on the track !
- Ironduke
The design has several places where two trains can pass each other. A single line layout with a few passing loops and sidings can provide more operational interest, as long as you're not an obsessive collector of new trains.Montfort wrote:With two tracks in parallel you can run two trains at the same time. Just a thought.
Hi, yes it's Hornby set track with some flexiIronduke wrote:Are you using Hornby set track? I see you have used a couple of flex tracks in there. I'm having a devil of a time to make it work in set track only.
Very nice.
Ok, i have tweaked the plan a bit. Are the reference numbers for the points old numbers, i have looked on Hattons and can't find them.Not sure whether to add a siding on the right side for an industry/factory etc.
If you replicated the inner loop on the right hand side as well you could have 2 trains running simultaneously.
Beware that curved points can be a real pain in the....tender-end.
![Idea :idea:](./images/smilies/icon_idea.gif)
- luckymucklebackit
You have also re-introduced that clearance issue at the entrance to the yard - beware of this especially when using small radius curves. If you have something parked on the main line and then run a loco into the yard it will probably side swipe
jim
jim
What about this one,luckymucklebackit wrote:You have also re-introduced that clearance issue at the entrance to the yard - beware of this especially when using small radius curves. If you have something parked on the main line and then run a loco into the yard it will probably side swipe
jim
- luckymucklebackit
That's Better
jim
jim
The crossing adds operational interest as it will challenge the operator(s) to keep trains apart, and on schedule. Perhaps not prototypical in practice, but that is a choice. Surely, diamond crossing exist somewhere in the UK? As to running the two lines parallel, not sure which two, but in either event the present format allows for some interesting structures, or village, in the open area. I would consider adding a gentle curvature to the back line, as it adds a little drama of a train sweeping through a curve in the countryside.
You might also wish to erect a little barrier tacked to the base board edges at the curves in the event something goes wonky and flies off the rails. Another thought is that the rear of the baseboard will be flush against the wall. Measure your arm. Two and a half feet is a comfortable reach to the back line, and I am 6 foot. Three feet is doable, but it will require a stretch. Anything beyond three feet will likely be out of reach.
I am arguing with myself whilst I layout some more replacement sections of excellent Hornby track (to replace American bits which are subsuitable) NOT to build this track plan. The expense, the time, the...the...
Now surely I do not deliberately crash my rail models deliberately, not too mention that after shipping I pay about double for any given item, but it certainly raises the stakes in a roundy-round. Fortunately, the rugged neoprene buffer bars prevent any damage, though I go to great lengths to not test them. You might also wish to erect a little barrier tacked to the base board edges at the curves in the event something goes wonky and flies off the rails. Another thought is that the rear of the baseboard will be flush against the wall. Measure your arm. Two and a half feet is a comfortable reach to the back line, and I am 6 foot. Three feet is doable, but it will require a stretch. Anything beyond three feet will likely be out of reach.
Nessie rocks!
This is what I mean by having 2 loops.
Hope it helps.Thanks
