Using Contiboard For A Baseboard?
MickleoverTestTrack
Re: Using Contiboard For A Baseboard?
Post by MickleoverTestTrack »
With regards to plywood; quality birch plywood is better than the cheap hardwood ply you get in the chain DIY stores.
RAF96
Post by RAF96 »
Birch plywood is superb but due to its quality of wood and waterproof adhesive can be hard to work. Try cutting qty 64 x 4” diameter lightening holes in 18mm thick birch ply. It gave my power saw a workout as well when cutting off 150 mm wide strips for baseboard framing. The formaldehyde glue stinks when heated by power tools - not nice, so wear a fume filter mask.
RAF Halton Brat - 96th Entry
β-tester
