Brave man b308 ........ You must also have a very 'good eye'.
This is where having at least a couple of us doing things we are able to represent different approaches and as modellers there are many different
ways to produce the same end game, or buildings in our case.
I feel the need to work to plans, that way I should have thought through & worked out any possible glitches. As an example here are a couple of my
plans with all required cutting dimensions shown. I found a started building in the bag of plans, this means we can progress through it's construction
reasonably quickly.
Here you can see the laminated front/rear wall. All windows & doors have been cut from the plain plasticard, embossed card is then stuck over the entire
piece leaving at leat 2 mm spare to overlap the ends only. Then using the cut-outs a scalpel is used to trim around thereby matching the original door &
window locations.
There is no overlap left on the embossed plasticard of the end pieces. These will now fit tight against the sides into the corner between the plain core
& extended embossed card of the front/backs. This allows easy, no step alignment of all the joints. When fully dried, I tend to leave overnight, the
excess can be easily trimmed away. If you want you can reinstate some mortar lines along the edge joint. I will admit I rarely do as the plain 0.60 mm
edge is not easily seen.
It's too cold to work in my garage on the layout so will go & do a little more on this.
