HOW TO--COACH LIGHTING.
Hi rmg !!
Thanks for the info. Seems very complicated to me. I chose the Rupert the Bear method for simplicity and I'm glad I did. What I've done so far will do the job for me. I'm not loking for total realism just some light in them. Also I have quite a few to do and even my simple method will take an age.
I don't seem to suffer from any overheating from the bulbs, so from that aspect they're okay. The heat generated from the bulbs is very local and doesn't travel far from the source. So as long as there is no direct contact with a surface they're okay.
Good luck with the project and post some photos when you're there.
My Best regards
BILL.
My Best regards
BILL.
Website: http://www.freewebs.com/thumbsupfilms
HOW TO-Coach Lighting http://www.newrailwaymodellers.co.uk/Fo ... 55&start=0
Hi Mr Levin
Well done!! As they say," a journey of a thousand miles begins with one step"
Good luck!!
Best Regards
BILL.
Good luck!!
Best Regards
BILL.
Only just spotted this M8internet (and your later explantion). I suggest you revise Ohm's Law.m8internet wrote:The bulb is only rated at 80mAwaz wrote:Can you explain why I need to use a resistor on a grain of wheat bulb??
You therefore need a resistor as the current supplied could be as high as 5A
Furthermore, if this were fitted to a train on DCC the current is always about 5A and there is a danger the bulb could overheat
Lighting Up
Hi,
I got it all, however I dont understand how the electric connection from the wheles on the track can conect to the screws on the bogie when modern bogies are made of a plastic type material, or am I just Thick...I just don't get the electrcal conection, please help.
Greg
Greg
- Ironduke
Re: Lighting Up
you have to make some pickups from metal that brush on the wheels, you can use strips of copper or brass, phosphor bronze wire... I don't know if there's a commercially available option.gregsexton wrote:Hi,
Greg
www.mainlytrains.com should sell all of the above.
- Ironduke
Oh yes of course.. I love Mainly Trains. I meant a commercially available prefabricated coach wheel power pickup option.Imberclub wrote:www.mainlytrains.com should sell all of the above.
Hi Chaps !!!
Guitar strings !!!!!!! Now why didn't I think of that?
I have 2 guitars and loads of strings. This, I think will make a lighter contact with the wheels so cutting down on the drag created by my copper wire pick-ups.
I'll try it in the next few days and report back.
Strings are not dear and there is alot in just one. Which guage to use is the question. The B and E strings are just fine wire. I'll try one of those.
Best Regards
BILL.
Best Regards
BILL.
Getting It
Hi All,
I twigged it! The first time I looked at it I had had a few Drinks and was a bit Piss"""d, I shall not be when I attempt this, I got all the Stuff, just one thing, is the foil just for reflection or to make the light go further, or does it serve a different purpose?
Greg
Greg
Hi Greg!!!
Sorry it's been so long to reply. Anyway if it's not too late, I put the foil there to reflect the light a bit, also I think, it tends to dissapate the heat from the bulb when using grain of wheat.
Best Regards
BILL.
Best Regards
BILL.
Hi Bill,
Thanks, no not too late...I just purchased a Rotacraft Mini Rotary Tool with 60 Pieces and a 400 piece accessory pack all for £23.00 from Maplins, what a BARGAIN!!!!!!! I can now do lots of work including the lighting. Will let you know if I do good...got 3 weeks holiday as from next Monday, so plenty of time to electricute myself! I go fishing anyway.
Regatrds,
Greg
Regatrds,
Greg
Lighting a NSE 2nd Class Coach
Hi Bill,
I did it! Bloody Fiddly isn't it, and took a wee while to get a good contact, still the whole coach is well lit. So I say Thank You for the instructions.....first attempt took me 3 hours!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!.
Still I know the pitfalls now and oddly enough I didn't electricute myself.
Greg
Greg
