I do like my Triang coaches, they are shorter than the modern scale ones which means I can run trains with more carriages and they go better round my tight curves. They are also very cheap and a good basis for a bit of freelance modelling.
Most of my coaches are the 9 inch ones, but I recently picked up a shorter 6 inch one. Some of the earlier short coaches suffered from banana syndrome, but this is one of the later generation with stable plastic and Mk 3 couplings. Unfortunately one of the bogies was damaged, so I put new ones underneath. I had to take quite a bit off the bogie pivot on the body to get the ride height down as the original bogies only had 10 mm wheels.
![Coach.JPG](./download/file.php?id=6443&sid=a3608e611db10a7f7e597fc683a281f6)
- Coach.JPG (35.48 KiB) Viewed 6486 times
So far I've put some glazing in and made an interior. This is becoming a lesson in recycling: the interior is made from cardboard packaging and bits of second hand balsa from a previous layout, while the glazing is also from packaging. I filled some of the chips in the balsa wood with wood filler from the hardware store.
![Interior.JPG](./download/file.php?id=6444&sid=a3608e611db10a7f7e597fc683a281f6)
- Interior.JPG (26.3 KiB) Viewed 6485 times
The next job is finishing the interior, painting the exterior French Blue and adding some passengers
