Following Daves (0121modeller) visit, heres the latest update on the latest goings on of the layout.
Electrics & trackwork
First off, Dave arrived literally as the soldering iron was cooling off having completed the preliminary wiring for the track feeds and was there to witness the first train running under its own power on both the up and down lines as well as through the low level storage loop. Naturally with the layout being built on two boards this meant that there is a board join to cross over.
A thread started by m8internet sowed the seeds for an idea which has resulted in me using copperclad PCB and deeply engraving a sleeper pattern into it. The rails are soldered to the remaining copper, and once ballasting commences the fine size of 2mm ballast should more than fill the engraved gaps.
As can be seen, a lick of paint has been applied which really does wonders in disguising the soldered up copperclad. The layout hinges at the rear in two sections, and so far this track joint has proven reliable in a few dozen lifts while I wired the rest of the laid track. And even though the timber at the board edge has warped my a few millimeters, the track join is still maintaining sufficient alignment for reliable running. As I mentioned earlier, trains are now able to run for a short distance on the layout. The entire board for the upper storage loops is still to be mounted while I wait for payday to be able to finish wiring up the point motors on the lower storage loops, so track laying has been forced to end at the passing loop for the goods yard. Still, that gives me roughy 20 feet of fully operable running line. The board for the goods yard is also on the needs to do list now, but this too needs to wait for the upper storage loop to be installed so that it is fixed at the correct height.
Tunnels & Bridges
In an earlier post I eluded to the re-emergence of some Canon Street landmarks. Naturally these haven't been recycled and butchered to fit a different layout, but they have been used to measure up and even provide templates for structures on this layout. Anyone who was following Canon Street will remember
THIS scratch built tunnel mouth; today that very tunnel mouth became a plastic primer demonstration
![Laughing :lol:](./images/smilies/icon_lol.gif)
, but not before it donated its template for the following...
![Image](http://i121.photobucket.com/albums/o240/ZunnanDeclawed/Railway%20Modelling/IMG_3295.jpg)
A card template of the original transfers the tunnel mouth profile to a blank sheet of Ratio plasticard.
![Image](http://i121.photobucket.com/albums/o240/ZunnanDeclawed/Railway%20Modelling/IMG_3299.jpg)
Ratio 00 arches this time provide the brickwork as I was unhappy with the appearance of the original, so have attacked the 'face' of this one in a different manner.
![Image](http://i121.photobucket.com/albums/o240/ZunnanDeclawed/Railway%20Modelling/IMG_3339.jpg)
A few embellishments such as the capping, butresses and a few other tweaks to the original as well as using 00 brick plasticard for a lining and this tunnel mouth really does have a more substantial feel to it over its original. The retaining walls will also see a similar revamping, they will be made in the same way as originally and use the same materials, but at the same time will be assembled differently to match the new tunnel mouth rather than the original work.
The girder overbridge (page 2 on the Canon Street thread) has also donated much of its original design and dimensions to a new build. The original was skewed to span 3 tracks at an angle, the new build is at 90 degrees to the rails but is now to span a 4 track main line carrying a main road rather than a two track railway, so the parapet wall on the deck also needs modifying to represent the different usage of the bridge. I was never particularly happy with the parapet walls of the original, so like the tunnel mouth, the original design while kept to in essence has been completely reworked and produced in a completely different way. As the original, this is a 3 piece bridge consisting of the bridge deck with girders and brick parapet wall (instead of the original handrails) and two abutments with completely reworked parapet walls.
![Image](http://i121.photobucket.com/albums/o240/ZunnanDeclawed/Railway%20Modelling/IMG_3356.jpg)
A pair of Canon Street stalwarts survey the new work.
Like the tunnel mouth, there is almost no comparison between the original and the rebuild. You can certainly see the DNA of where it came from, but a few years of building models in other scales has given me a new arsenal of tricks to employ when scratch building. Things like the bedstones, home made capping stones, even the way the butresses are built so that the girders slot into them rather than just rest on top of the abutments. Not to mention that it was quicker to build than the original was too!
Bring on those retaining walls!!!
