Has anyone tried Railway Scenic's Stay Alive kits?
Tom@Crewe
Postby Tom@Crewe » Sun May 10, 2020 1:45 pm
Hi, Has anyone tried Railway Scenic's Stay Alive kits?
They have 4 sizes 1000uf, 2200uf, 3300uf and 4700uf (they do give dimensions too)
I know no one can probably be accurate for all applications but what sort of time would these give to bridge loss of power?
I want to fit them to a Bachmann Jinty and Gronk so physical size is probably going to limit me.
They seem cheep as chips but are they worth it?
https://www.railwayscenics.com/dcc-and-wire-kits-c-20_283.html?osCsid=682d3edc4kcmsfamm3m4d15c10
Never enough time...........
fourtytwo
Re: Has anyone tried Railway Scenic's Stay Alive kits?
Postby fourtytwo » Mon May 11, 2020 8:18 pm
Am I correct in thinking you mean in conjunction with a DCC layout ?
I tried a few experiments in a DC layout with very limited success as the voltage stored is just the normal motor voltage so the flywheel effect is somewhat limited AND I model N-gauge steam so almost no space in for example a 57xx!!
Tom@Crewe
Postby Tom@Crewe » Tue May 12, 2020 4:19 pm
Yes it is for a DCC loco
Postby End2end » Tue May 12, 2020 6:33 pm
You could probably make up 3 or 4 of them for the same price if you bought the components yourself.
Postby Flashbang » Tue May 12, 2020 7:16 pm
TBH the uF values given are not that large. I won't expect a Stay Alive at those values to give more than a second or so movement. But a lot will depend on the loco they are fitted into and size of the capacitance offered.
RAF96
Postby RAF96 » Tue May 12, 2020 8:48 pm
RAF Halton Brat - 96th Entry
β-tester
Peterm
Postby Peterm » Tue May 12, 2020 11:41 pm
If you don't want to make your own, Lais Kung Fu stay/keep alives pack a hefty punch and come with the charging circuit built in. They can be bought as a square package at 13mm long by about 9mm square or a flatter but longer pack. As Flashbang says, you won't get much out of 4,700uf.
PinkNosedPenguin
Postby PinkNosedPenguin » Thu May 14, 2020 1:49 pm
TCS have a range of keep alives: https://tcsdcc.com/accessories/keep-alive which are apparently now only available from them direct (but within the UK):
  • KA3 and 4 claim to power a loco for 6 to 20 seconds - I have used them on my little O-16.5 locos and definitely got at least 6 seconds.
  • KA1 and 2 are physically much smaller but have "approximately one-third of the capacitance of KA3/KA4 devices"
Return to “Electronics”
