Faulty Led repair
James109
Faulty Led repair
Postby James109 » Sun Oct 13, 2019 12:28 pm
abenn
Re: Faulty Led repair
Postby abenn » Mon Oct 14, 2019 8:37 pm
I don't understand: He demonstrated that the faulty LED was getting 6.5v and, I think, mentioned that the voltage-regulator had failed open-circuit, which would have eventually caused the LED to fail. So why didn't he change the voltage regulator as well -- or did I miss it?
Ironduke
Postby Ironduke » Tue Oct 15, 2019 12:07 am
abenn wrote:I don't understand: He demonstrated that the faulty LED was getting 6.5v and, I think, mentioned that the voltage-regulator had failed open-circuit, which would have eventually caused the LED to fail. So why didn't he change the voltage regulator as well -- or did I miss it?
What I got was that the LED had failed open circuit. I don't think a voltage regulator was mentioned. It should have measured ~2V but was measuring 6.5V. That is not a cause of the faulty LED but a symptom, it's the LED that makes it 2V.
The LED does shine very brightly when DCC is connected. I wonder if the LED is being driven directly from the DCC input and what the circuit is.
Ironduke
Postby Ironduke » Tue Oct 15, 2019 12:40 am
Ironduke wrote:I wonder if the LED is being driven directly from the DCC input and what the circuit is.
Hm, yes it is. According to their circuit (see page 4) the indicator LED is reverse parallel across the LED input of an opto-coupler and has in series 2x2K resistors in parallel (so 1K basically). 1K might be a bit low if the DCC p-p voltage is very high. I wonder why they thought they needed 2 resistors in parallel? Lucky the opto-coupler didn't blow really.
So the reason it measures 6.5V is probably that the multimeter is actually measuring an alternating voltage , ~2v when the opto LED is on and -ve full DCC voltage when it's reversed. When both LEDs are working you'd get alternating +/- 2V.
I'd try removing R8 and see if it still works.
Ironduke
Postby Ironduke » Tue Oct 15, 2019 4:07 am
Ironduke wrote:1K might be a bit low if the DCC p-p voltage is very high.
Actually belay that. Even if DCC peak voltage was 18V and the forward voltage drop on the opto-coupler input was 1.7 (which is the max for a 6N137 apparently) you'd only get 16.3mA coming through the resistors ((18V-1.7)/1000). Maybe the indicator LED was just not a very good one?
James109
Postby James109 » Tue Oct 15, 2019 5:55 pm
Been working now for 3 days none stop, led is no where near as bright so thinking just a faulty led, thanks for the comments. Still think for a hobby kit it's amazing.
Return to “Electronics”
