PCU2 unit
Brian2
PCU2 unit
Postby Brian2 » Fri Sep 13, 2019 9:33 am
I am using a Gaugemaster 100MO,PCU2 GM CDU and PL11 point motors. there doesn't seem to be anywhere for the green wire to go. Gaugemaster don't have a wiring diagram for this set up and their explanation over the phone has only confused. I have scoured Brian Lamberts site but everything seems to point to having to use a PCU1 and then the PCU2 as a slave.....problem, Gaugemaster still make the 2 but the 1 is discontinued.
Any help would be greatly appreciated.
Imageuntitled (1 of 1)-7 by Brian Tompkins, on Flickr
Roger (RJ)
Re: PCU2 unit
Postby Roger (RJ) » Fri Sep 13, 2019 9:47 am
I would make an educated guess that the green (common) wire needs to connect to one of the CDU output terminals or the input side of the PCU where the CDU connects.
Paul-H
Re: PCU2 unit
Postby Paul-H » Fri Sep 13, 2019 10:46 am
Brian2
Re: PCU2 unit
Postby Brian2 » Fri Sep 13, 2019 12:36 pm
Thanks both.
Yes it's me being stupid. I looked at the diagram and it showed leads coming from the back and the front., whereas mine has three from the front. But yes the green goes back to the CDU.
This is a diagram marked up by Greg at Gaugemaster ( my son called in, he lives near bye) the point motors looked completely different to mine.
ImageATT76766 1 by Brian Tompkins, on Flickr
Thanks again.
PS Help came flooding in, even got a lovely reply from the Guru Brian Lambert
Return to “Electronics”
