1. Bridge rectifier SIP4 3amp 50volt
2. Capacitor 330uF 25 volt
Or are other values better?
The other thing i wasn't sure on was the DCC track is around 19 volt & the led's are 12 volt? IE: Will i cook the led's.
Should i add somthing??
Thankss.
TimberSurf wrote:As said by Ironduke, a bridge rectifier greater than 40mA is needed so anything above that will do. (i.e. 100mA or 0.5mA) [Technically it should be a Schmitt type]
collectors wrote:Hi Bramshot, the carriages a Bachmann on30's & come with one led in each carriage that's not very good, hence the upgrade. So the wheel connections are in place.
collectors wrote:DB107 DIP4 Single Phase 1A Glass Passivized Bridge Rectifiers, will these be OK,?
Ironduke wrote:collectors wrote:DB107 DIP4 Single Phase 1A Glass Passivized Bridge Rectifiers, will these be OK,?
They look great.
