Conrad PWM controller kit
Montfort
Postby Montfort » Tue Oct 09, 2018 10:42 am
Hello,
Has anyone ever tried to use the Conrad PWM controller kit ?
All your advices would be very appreciated. Thanks.
Back on the track !
Ironduke
Re: Conrad PWM controller kit
Postby Ironduke » Wed Oct 10, 2018 8:03 am
I thought you had this all sorted?
It's a very basic circuit based on a 555 timer. Nothing wrong with that apart from the price (compared to the ebay unit). You would need to replace the trimpot with a similar value of potentiometer you can stick a knob onto, and of course add a reversing switch and a box.
I can't read any of the user manuals (I assume your French is better than mine) but I think the pot is a 10K linear type.
Montfort
Postby Montfort » Wed Oct 10, 2018 9:38 am
Thanks for your reply. I found this. Hope that helps:
https://produktinfo.conrad.com/datenbla ... Motore.pdf
Back on the track !
Ironduke
Postby Ironduke » Wed Oct 10, 2018 10:40 am
Montfort wrote:Thanks for your reply. I found this. Hope that helps:
That doesn't seem to be the same product you linked to first. I was looking at this manual: https://produktinfo.conrad.com/datenbla ... lateur.pdf
Montfort
Postby Montfort » Wed Oct 10, 2018 11:11 am
Oops ! You're right. This electronic diagram must be better:
Back on the track !
Return to “Electronics”
