PECO electrofrog fault.
Tiddles
Postby Tiddles » Thu Feb 15, 2018 6:29 pm
Got a brand new PECO SL-E89 today LH.
It is dead down the left track :o
Any ideas :|
Will take it back to the shop :twisted:
Paul-H
Re: PECO electrofrog fault.
Postby Paul-H » Thu Feb 15, 2018 10:00 pm
Surly on a LH point the LH rail is one solid rail, how can it be dead, unless it's not fed properly?
I think we need a little more of an explanation, unless I have missed something obvious ;)
Tiddles
Postby Tiddles » Thu Feb 15, 2018 10:29 pm
Paul-H wrote:Surly on a LH point the LH rail is one solid rail, how can it be dead, unless it's not fed properly?
When set straight the loco goes through. When set to the left the loco stops dead as soon as it clears the point blades.
D605Eagle
Postby D605Eagle » Thu Feb 15, 2018 10:34 pm
look underneath it. There are splits in the track that are bridged with spot welded pieces of wire. Maybe one is missing or has become disconnected at one end.
Tiddles
Postby Tiddles » Sat Feb 17, 2018 11:58 pm
When back to the shop and swapped id for another one, all working now :D
Shop owner did not believe me and was very helpful, simply said that he has never had a problem with them before.
Papyrus
Postby Papyrus » Sun Feb 18, 2018 4:11 pm
I don't doubt that you had a genuine problem. But I have thought that I had the same problem, then discovered that the switch blade wasn't contacting the stock rail correctly, because the tie bar was obstructed and wasn't going right the way across.
Alan
Return to “Electronics”
