VERY thin wire
dan8400
VERY thin wire
Postby dan8400 » Sun Nov 27, 2016 8:09 am
Hi everyone.
I wondered if I can buy very thin wire like the sort in the Traintronics signals. I bought a wills modern level crossing kit and I'm going to add LED's. Obviously the poles up to the signal heads are quite thin
Dan
Teedoubleudee
Re: VERY thin wire
Postby Teedoubleudee » Sun Nov 27, 2016 9:34 am
Do a search on " solderable Enamelled Copper winding wire". This is the wire used for forming coils in relays and transformers etc. and can be as thin as 0.2mm. Unfortunately, because it is manufactured for this purpose it seems to only be available in reels. A video on how to solder it can be found here:
https://www.youtube.com/watch?v=Mjjryf2aqaY
Tricky Dicky
Re: VERY thin wire
Postby Tricky Dicky » Sun Nov 27, 2016 9:56 am
dan8400 wrote:Hi everyone.
Dan
Old ear plugs and headphones for the likes of IPods and mobiles are usually a good source of very thin wires.
Richard
Ironduke
Re: VERY thin wire
Postby Ironduke » Sun Nov 27, 2016 10:31 am
wire-wrap wire is very thin (30AWG) and usually teflon coated which makes it easy to solder without the insulation shrinking on you.
http://uk.farnell.com/ok-industries/r-3 ... dp/7333675
Suzie
Re: VERY thin wire
Postby Suzie » Sun Nov 27, 2016 11:20 am
Roadrunner wire is about 38SWG so very thin, and it comes in four colours. Four small reels will cost about £10 and should last for quite a while for all those jobs that need very thin wire.
RAF96
Re: VERY thin wire
Postby RAF96 » Sun Nov 27, 2016 2:02 pm
You may be able to use electric paint instead of physical wire.
RAF Halton Brat - 96th Entry
β-tester
dan8400
Re: VERY thin wire
Postby dan8400 » Mon Nov 28, 2016 5:59 pm
Thanks for the replies everyone.
I have old headphones so I'll try that first.
Dan
Return to “Electronics”
