slow down in tunnel
fancyfifer
slow down in tunnel
Postby fancyfifer » Fri Sep 21, 2012 9:45 am
I remember years ago reading of a way of slowing down a train while in a tunnel or covered section so it did not appear at the other end seconds later, as I remember it involved installing a resistor or some other electronic piece on the track, any information on this subject would be appreciated.
luckymucklebackit
Re: slow down in tunnel
Postby luckymucklebackit » Fri Sep 21, 2012 10:42 am
Essex2Visuvesi
Postby Essex2Visuvesi » Fri Sep 21, 2012 11:46 am
quick and dirty method for DC running below
Fleischmann do a suitable Variable resisor part number 6954
http://www.amazon.co.uk/Fleischmann-695 ... B0007XUYI8
slow section.jpg (13.9 KiB) Viewed 1117 times
Proud member of the OAM
Andrew S Harvey
Postby Andrew S Harvey » Fri Sep 21, 2012 4:07 pm
Or you could try turning the knob on the controller own! :D
Postby Flashbang » Fri Sep 21, 2012 4:41 pm
If you opt for variable resistance don't be tempted to use a variable pot as supplied for radio/hi fi use. Their current rating is well below any locos motor current and they will quickly burn out.
The other options are to use a stand alone controller to feed the isolated slow down section, even a cheap Train set controller will do the job. Or use a variable voltage regulator circuit where the output of the regulator feeds the isolated section.
peroni
Postby peroni » Fri Sep 21, 2012 11:09 pm
This is the unit that I used when I was using DC, I have gone to DCC these days.
http://talkingelectronics.com/projects/ ... tcher.html
fancyfifer
Postby fancyfifer » Sun Sep 23, 2012 11:38 am
thanks, that's a help
Return to “Electronics”
