Lighting Help And Advice
Dwarfboysim
Postby Dwarfboysim » Sat Jun 16, 2012 8:11 am
Hi all,
Well I have all the ballast down, point motors in, bus wire etc. Now I want to make a start on lights. I have purchased some of the Hornby Skale Lighting stuff to experiment with. I was also looking at the following on ebay: http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... Track=true
Do you think these could have the Hornby Skale Lighting plugs attached to add them in? I am working on powering the system via my Select with it's 4 AMP PSU as I now use an Elite to Power the Track, Trains and Point Motors.
If anyone has any advice along with pictures of what they have done, things to watch out for etc with wiring that would be great.
Thanks,
Dwarfboysim
Cinders And Ashes I'm Stuck, And He Was!!
My Blog
YouTube Channel
Model Rail Facebook Page
musketter
Re: Lighting Help And Advice
Postby musketter » Sat Jun 16, 2012 9:23 am
1 quick question, is the power supply AC or DC ?
But it only broke when I dropped it
Postby Flashbang » Sat Jun 16, 2012 9:59 am
These lights have been discussed recently.. See this topic http://www.newrailwaymodellers.co.uk/Forums/viewtopic.php?f=7&t=38237&start=15 especially page 2 but equally page one too.
16:06:12 @10:48 Edit to correct link
Postby Bufferstop » Sat Jun 16, 2012 10:12 am
Hi Flashbang - hope you don't mind me fixing your link, think it was missing a"/" http://www.newrailwaymodellers.co.uk/Forums/viewtopic.php?f=7&t=38237&start=15
John W
aka Bufferstop
Postby Flashbang » Sat Jun 16, 2012 10:49 am
Thanks John
I have also corrected it too. :D
Dwarfboysim
Postby Dwarfboysim » Sat Jun 16, 2012 9:40 pm
Hi,
So if I am reading the picture correctly if I wanted to add Skale Lighting plugs to these I would need to use 2 plugs per lamp post (being 1 plug per globe) and connect 1 Silver and 1 of the other wire into each?
Thanks,
Dwarfboysim
My Blog
YouTube Channel
Postby Flashbang » Sun Jun 17, 2012 3:19 pm
Dwarfboysim wrote:Hi,
Thanks,
Dwarfboysim
No,
You would need one plug per lamppost. Connect the two white wires into the plug and then joint the two silver wires together and insulate the joint with a piece of PVC insulating tape.
Dwarfboysim
Postby Dwarfboysim » Sat Sep 01, 2018 9:50 am
Hi all,
Apologies for the delayed response. The Hornby Skaledale Lightining gave me too much grief particularly with try to wire their little plugs. I have now switched over to LED strip lighting for the buildings but need to find a way to dull this down as they are VERY bright. Also looking for some double sided lamp posts running LED lights to illuminate the platform if anyone can provide advice.
Thanks,
Dwarfboysim
My Blog
YouTube Channel
Postby End2end » Sat Sep 01, 2018 12:20 pm
Add 1KOHm resistors inline to bring the light level down.
Dwarfboysim
Postby Dwarfboysim » Sat Sep 01, 2018 12:37 pm
On the positive or negative side or one on each?
My Blog
YouTube Channel
Postby End2end » Sat Sep 01, 2018 12:38 pm
Sorry, Positive side.
Also if you find some lights are just a little too bright (rather than very bright) you can paint them with clear varnish.
Just as a side note, I add a 1KOHm resistor to ALL my LED's so they limit the power.
Hope it helps.
Postby TimberSurf » Sat Sep 01, 2018 2:14 pm
Or if you dont want to experiment with different values of resistors as above, how about variable dimming!
Bramshot
Postby Bramshot » Sun Sep 02, 2018 10:22 am
Dwarfboysim wrote:Hi all,
Dwarfboysim
Have you tried Layouts4U? (No affiliation).
I used them for almost all my lights, and a good source for led strips, miniature plugs and sockets etc.
Dwarfboysim
Postby Dwarfboysim » Wed Sep 05, 2018 2:40 am
HI,
Is the colour code for the 1K OHM resistor you use BROWN, BLACK, RED, GOLD?
Even a picture would be great. Also does it matter which way they are wired on the positive eg which end closest to LED strip etc?
Thanks,
Dwarfboysim
My Blog
YouTube Channel
Postby TimberSurf » Wed Sep 05, 2018 8:44 am
See colour code here
The resistor can go either side of the LED, its orientation makes no difference
Return to “Electronics”
