Retro fitting building internal lighting
brober
Postby brober » Mon May 03, 2021 5:35 pm
I am wanting to retro fit LED lights into some Metcalfe buildings (house, cottage, etc). Has anyone done this successfully and if so how. What LEDs did you use?
aleopardstail
Re: Retro fitting building internal lighting
Postby aleopardstail » Wed May 05, 2021 10:17 pm
it was a few years back but yes.
I used 5mm LEDs, white ones, on a 12v DC supply, IIRC about a 1k resistor but you would need to check the spec of the LEDs. higher resistors dim the LED a bit, too high and you get nothing
solder the resistor to one leg, doesn't matter which, one resistor per LED.
its harder with multi-level buildings with an internal floor
trick is to make sure the LED can't be seen through the window, also watch out as any gaps in the kit will show up amazingly well
its much easier to add lights as you build, but you certainly can add them after
Ironduke
Postby Ironduke » Wed May 05, 2021 11:01 pm
These led lighting strips come on a roll and they are self adhesive. You can cut them into groups of three. They have a resistor included so they run on 12V.
brober
Postby brober » Thu May 06, 2021 10:21 am
Rob,
Thanks for the pic. That looks like it will do the job with some flexibility. Would you be able to give me some more details on spec, manufacturer and source please.
Bruce
Ironduke
Postby Ironduke » Thu May 06, 2021 12:57 pm
Hi Bruce,
I bought mine in Australia.
https://www.jaycar.co.uk/low-cost-5m-fl ... e/p/ZD0577
Ironduke
Postby Ironduke » Thu May 06, 2021 1:09 pm
actually, even if you are in the UK, they might be cheaper to buy from here.
https://www.ledsales.com.au/index.php?m ... ts_id=1329
brober
Postby brober » Thu May 06, 2021 2:52 pm
Thanks Rob,. These appear to be water resistant. I think I can down spec to internal use only. Let's see what Mr eBay and Mr Amazon have. Appreciate your help.
Bruce
Ironduke
Postby Ironduke » Thu May 06, 2021 11:41 pm
brober wrote: These appear to be water resistant.
yeah they were out of stock of their normal ones.
