Airfix / GMR decal / signage removal
lenht1951
Postby lenht1951 » Wed Sep 27, 2017 5:21 pm
Hi, has anyone tried to remove the decal / signage from the Airfix / GMR range of wagons. I have tried brake fluid and cotton bud and although this was successful on the Hornby range it failed miserably on the Airfix and did not fade it at all. Any ideas at all on how to remove. Thanks.
Mike Parkes
Re: Airfix / GMR decal / signage removal
Postby Mike Parkes » Wed Sep 27, 2017 9:42 pm
Cannot recall trying to remove their lettering.
There are a variety of solutions that may work depending on how the lettering was applied.
Enamel thinners (defiantly works with Mainline and older Bachmann models)
Typists eraser (difficult to find these days)
T-cut
Toothpick with or without T-cut
Make sure first though that you have well washed the model - some brake fluids can react badly with the plastic body.
lenht1951
Postby lenht1951 » Thu Sep 28, 2017 11:58 pm
Cheers Mike I will give them a go and report further.
Postby mumbles » Fri Sep 29, 2017 8:13 am
Been a long time since I did anything like that, but would a fiberglass pencil work? Are you repainting?
lenht1951
Postby lenht1951 » Sun Oct 22, 2017 9:29 pm
For the info of anyone attempting this. Well the thinners failed, and the brake fluid both failed to work on the Hornby, Mainline and the Airfix. I next tried the glass fibre pen which worked great on the Hornby brake van and the Mainline bogie milk vans without damage to the paint, unfortunately it took off the top layer of paint around the decals on the Airfix brake van, LMS wagon grey here I come. :roll:
