Are you using PLA or ABS for your printingBufferstop wrote:I'm just at the stage of working out what you have to do to stop the prints from curling at the ends
Timbologist
I made 6 wheelbarrows at once resin cost was AU 11 cents this includes a raft that is scrap 1.33 ml time 4h 15m 48s approxTimberSurf wrote:Should be cheap to make, as little resin!
What are the best settings for the Monocure resin with the Wanhao Duplicator 7 printer?
Monocure RAPID: 7 second layers. 3 base layers at 40 seconds and 0.050mm resolution. (White, Clear, Black, Blue and Grey)
Monocure STANDARD: 20 second layers, 4 base at 90 seconds and 0.035 - 0.1mm resolution. (White, Clear, Blue, Red, Yellow, Grey, Black)
How is Monocure 3D RAPID resin different from the STANDARD formula?
Our Rapid Resin has been developed for low powered LED DLP type printers (like the Wanhao D7) so it can have faster layer curing times. The STANDARD resin will cure at layer speeds of 15-20 seconds, while the RAPID will cure at 5-8 Seconds depending on the layer thickness.
