thanxs
stuartp wrote:Ah, MTK. The only kits on which I've ever had to resort to using woodworking tools.
Personally I'd use the two-part car body epoxy fillers on these rather than hobby fillers. The car stuff is designed to bond to metal (the sheet metal parts of MTK kits are usually aluminium) and it's generally tougher and has a bit more 'oomphh' abou it. The hobby fillers will five you a much smoother surface but they're usually toluene (solvent) based which is great if you want them to bond to plastic but pretty hopeless at sticking to anything which toluene doesn't dissolve.
Essex2Visuvesi wrote:I have used the revell plasto with great success on ply and stripwood when building my model boats
CaptainElectra wrote:Milliput is also good for any finer filling, such as reshaping the ends.
