Slaters plastikard
lenht1951
Slaters plastikard
Post by lenht1951 »
Just a quickie, what is the best method for sticking embossed slater plastikard to a painted cork covered baseboard. :D
heda
Re: Slaters plastikard
Post by heda »
I use UHU to stick it to card but haven't tried sticking it to cork so I'd suggest waiting for some more replies before trying.
When you stick it down I would put a flat weight (books) to hold it flat while the glue sets.
lenht1951
Post by lenht1951 »
Cheers Dave, I was toying with the idea of strong double sided tape, if anyone has used this method would be interesting to have feedback.
Post by Bufferstop »
I've used double sided tape to hold down normal plasticard when solvent wouldn't hold it to the board and Bostic clear caused it to bubble. I thinkit might depend on the degree to which the embossing affects the back of the card. The type which has a very minimal layer of foam on its surface (rather than being padded) might overcome the voids created by the embossing.
