1/32 Scale Diorama
Daniel
1/32 Scale Diorama
Postby Daniel » Mon Nov 02, 2020 11:41 am
Also if Flickr gives a much older date, this first photo of the series was taken de 4 April this year.
The baseboard is 80cm X 120cm and built with a very light 10mm thick plywood named "Ceiba" for the frame and 4mm MDF for the top:
ImageP1190187 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190188 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190189 (2) by Daniel Osvaldo Caso, on Flickr
The ply strokes where PVA glued and fastened for drying with screws that, of course, will never been removed because I am too lazy for doing so.
The 4mm MDF top was also glued with PVA but and no screws but small spikes arranged the old way: /\/\/\/\/\ .
There was not really a plan but just a desire to 'do something' inspired by an old French postcard where an small arch bridge (or viaduct?) is being built:
ImageP1190258 (2) by Daniel Osvaldo Caso, on Flickr
A piece of paper convinced me to this general idea:
ImageP1190193 (2) by Daniel Osvaldo Caso, on Flickr
I love to make plans. I hate to follow them. But -at least in my case- plans have the function of unlocking my creativity which tolerate no bosses even if they are just lines on a piece of paper.
So all what follows is the real story in images.
IMPORTANT:
If you like or want to get any explanations, please, feel really free to ask.
ImageP1190194 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190195 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190196 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190197 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190198 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190199 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190202 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190203 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190204 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190205 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190206 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190207 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190208 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190212 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190213 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190214 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190215 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190241 (2) by Daniel Osvaldo Caso, on Flickr
More in next message.
Daniel
Daniel
Re: 1/32 Scale Diorama
Postby Daniel » Mon Nov 02, 2020 11:55 am
ImageP1190284 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190285 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190286 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190287 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190288 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190289 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190290 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190291 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190292 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190293 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190294 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190295 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190296 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190297 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190298 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190299 (2) by Daniel Osvaldo Caso, on Flickr
The rocks you see added in next photos are made of isolating foam used for real buildings. They were part of two previous layouts now dismantled and were recycled hier
ImageP1190305 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
Daniel
Postby Daniel » Mon Nov 02, 2020 12:09 pm
Daniel
Postby Daniel » Mon Nov 02, 2020 12:16 pm
Daniel
Postby Daniel » Mon Nov 02, 2020 12:31 pm
ImageP1190466 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190467 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190469 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190470 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190477 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190480 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190482 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190484 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190486 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190487 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190488 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190489 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190491 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190500 (2) by Daniel Osvaldo Caso, on Flickr
What follows is a bit more technical and there are plenty of other ways to do it. But I wanted badly this machine and this project was the perfect excuse to get it.
The photos that show how I made the wooden arch sections for the bridge scaffold using a special device I've made using pieces of 6mm MDF
ImageP1190518 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190519 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190520 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190521 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190522 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190523 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190524 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190525 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190526 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190527 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190528 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190529 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190530 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190531 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190532 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190533 (2) by Daniel Osvaldo Caso, on Flickr
So were the arch sections made, one by one, for the four arches needed for the scaffold.
Inb next message the photos show the cutting all sections to the right angle:
ImageP1190534 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
More later because my belly is asking hot coffee.
Daniel
Mannick
Postby Mannick » Mon Nov 02, 2020 12:53 pm
A nice start. I'm following with a great interest.
Daniel
Postby Daniel » Mon Nov 02, 2020 12:58 pm
Thank you Mannick.
I hope you'll keep enjoying.
Does the photo of the Porter mean you model 0n30?
Daniel
Daniel
Postby Daniel » Mon Nov 02, 2020 1:13 pm
ImageP1190513 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190514 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190515 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190516 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190517 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190537 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190538 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190539 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190540 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190541 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190542 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190554 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190555 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190556 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190557 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190559 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190558 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190610 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190626 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190627 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190628 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190621 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190623 (3) by Daniel Osvaldo Caso, on Flickr
ImageP1190622 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190630 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190631 (2) by Daniel Osvaldo Caso, on Flickr
What happenned? Well, there were several not too serious issues but when I saw the whole structure in place I realized that my impulsive move to stain all the parts was simply wrong: such a scaffold is made ussually with untreated wood that may have had several previous lives but certainly not a stain or neat paint. So I took a second chance:
ImageP1190633 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190648 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190651 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190650 (2) by Daniel Osvaldo Caso, on Flickr
After that first job and making the second set I love the little Proxxon!
ImageP1190655 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190667 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190668 (2) by Daniel Osvaldo Caso, on Flickr
Daniel
Mannick
Postby Mannick » Mon Nov 02, 2020 1:14 pm
Daniel wrote:Does the photo of the Porter mean you model 0n30?
Sometimes...
Daniel
Postby Daniel » Mon Nov 02, 2020 1:25 pm
Mannick
Postby Mannick » Mon Nov 02, 2020 1:42 pm
Daniel
Postby Daniel » Mon Nov 02, 2020 1:46 pm
Thank you again.
I deduce you still like it. :)
Daniel
Daniel
Postby Daniel » Mon Nov 02, 2020 1:57 pm
ImageP1190848 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190851 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190852 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190853 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190854 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190855 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190856 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190857 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190858 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190859 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190860 (3) by Daniel Osvaldo Caso, on Flickr
ImageP1190861 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190863 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190864 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190865 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190866 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190867 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190868 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190869 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190870 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190871 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190872 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190873 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190874 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190875 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190876 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190878 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190879 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190880 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190881 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190882 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190883 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190885 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190886 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190887 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190888 (2) by Daniel Osvaldo Caso, on Flickr
ImageP1190889 (2) by Daniel Osvaldo Caso, on Flickr
Return to “Scenery”
