Road surface
shunter68
Road surface
Postby shunter68 » Sun Jul 09, 2017 12:51 pm
Hi need some help on a road I am building alongside side a cliff face. The road will run along side a cliff face on each side and eventually leading to a coal depot and hut. What surface is best to use for this as I want it to look rough. Any advice will be welcomed. :D
Re: Road surface
Postby Bufferstop » Sun Jul 09, 2017 4:23 pm
Use a slow setting plaster, form up the sides by hand, and when it's getting firmer put the ruts in with the wheels of a junk car or van. Apply paint to the road surface and shake on fine sand, then when dry vac off the surplus. then paint any grassy bits and static grass them.
shunter68
Re: Road surface
Postby shunter68 » Mon Jul 10, 2017 11:37 am
Thanks Bufferstop for the advice will try this method. :D
Re: Road surface
Postby b308 » Mon Jul 10, 2017 12:43 pm
That's exactly how I did mine as well, the colour will depend on the area modelled, mine was a light cream/brown.
Return to “Scenery”
