Building a hill...
Beynac
Re: Building a hill...
Postby Beynac » Fri Apr 07, 2017 5:10 pm
I'm planning to pay a visit to my local model railway shop (I'm lucky to have it).
I'm just a guy who wants to play with his toys. Image
luckymucklebackit
Postby luckymucklebackit » Sun Apr 09, 2017 3:57 pm
Beynac wrote:First coat of brown paint (I know it looks like a big chocolate cake :lol: ):
To be continued...
As I mentioned on another thread, on the steeper parts of the slope you should go for a more mixed grey to simulate rock rather than brown earth, earth does not naturally form steep slopes, hence the reason you get landslips, rock however can be found in near vertical faces.
Beynac
Postby Beynac » Sun Apr 09, 2017 4:08 pm
You are absolutely right. I still have a lot to learn before I can build a hill that really looks like a hill. I also made several mistakes that I wouldn't do again. :oops:
Beynac
Postby Beynac » Tue Apr 11, 2017 10:04 am
I bought all that stuff from Faller in my local model railway shop:
FALLER FORUMS 01.jpg (280.03 KiB) Viewed 900 times
Another and biggest hill (Ø 660mm and it's not the devil's number) is under construction. Photo ASAP.
Beynac
Postby Beynac » Tue Apr 11, 2017 5:40 pm
It's just the beginning for my new hill:
HILL #7.jpg (159.61 KiB) Viewed 885 times
Beynac
Postby Beynac » Wed Apr 12, 2017 2:56 pm
Step 2: a big "newspaper pie": :mrgreen:
HILL #8.jpg (291.87 KiB) Viewed 845 times
Beynac
Postby Beynac » Thu Apr 13, 2017 11:06 am
Step 3: Another big chocolate cake: :lol:
HILL #9.jpg (131.33 KiB) Viewed 844 times
Beynac
Spreading flocks and scatters
Postby Beynac » Thu Apr 13, 2017 3:12 pm
Hi all and one !
What do you use for spreading flocks and scatters on your layouts ? Something like that or anything else ? Thanks for all your answers.
Re: Spreading flocks and scatters
Postby Dad-1 » Thu Apr 13, 2017 4:54 pm
I just release from a small pinch between my thumb and forefinger.
It doesn't stand up in the way static applications do, but then looking
around here neither will all the natural grass !!
It's also a lot cheaper, but needs a specific gluing sequence and I use
several different colours & makes to get a more variable natural look.
Geoff T
Beynac
Postby Beynac » Thu Apr 13, 2017 5:53 pm
Good idea. Thanks.
Beynac
Postby Beynac » Thu Apr 13, 2017 5:56 pm
The new hill fits exactly in the middle of my first circle of track. The green colour hides a lot of junk I left around the layout. :oops:
HILL #10.jpg (211.23 KiB) Viewed 834 times
GeraldH
Postby GeraldH » Thu Apr 13, 2017 8:23 pm
Dad-1 wrote:I just release from a small pinch between my thumb and forefinger.
Geoff T
I'm also a thumb and forefinger sprinkler. I find that the glue I'm sprinkling on is critical - there needs to be plenty of it and I sometimes have to push the flock down after sprinkling to make sure it is properly fixed, or it just blows off later.
Postby Dad-1 » Thu Apr 13, 2017 8:44 pm
Hi GeraldH,
We obviously came from the same school of alternative thinking !!
As you say the glue application is part of getting the sprinkle method
to work successfully.
I only work on small areas at a time (difficult to be specific about that).
First I paint with neat quality PVA (Evo-stik Woodworker) then sprinkle on
a rubbery woodland scenics burnt grass ? This lets the glue soak into it to
give a good foundation. Then I use Jarvis Spring, Jarvis Summer, Noch
(Gaugemaster?) spring, Noch (Gaugemaster) summer, with some Jarvis
Autumn, Woodland Scenics Harvest, making a 'wet' patch the darker Noch
moorland, Oh and some summer meadow by Noch with colours in odd
places.
I then spray with water and drip on a weak thinned PVA from an eye dropper
It's only by experimenting that you get the right amounts of each and yes
some of the final scatter of Gaugemaster summer will blow off.
The finished grass can take loads of 'stick' as my 'Thomas' layout has proved.
Never lay grass this way if it's cold & damp, or you could find the PVA will
become stained with a white deposit from not drying out fast enough.
Beynac
Postby Beynac » Fri Apr 14, 2017 10:58 am
Thanks for all your advices. My Faller stuff is arriving today. Then I will become a gardener or someone like that. :mrgreen:
Beynac
Postby Beynac » Fri Apr 14, 2017 4:03 pm
The four seasons pizza is now ready (sorry, I'm not picasso :mrgreen: ).
Anyway, I had a lot of fun to make my first try with these scatters. All your constructive criticism are welcome.
HILL #11.jpg (385.5 KiB) Viewed 820 times
Return to “Scenery”
